Water Damage
Old 03-24-2005, 09:05 AM   #1
Painting Contractor
Humble Abode's Avatar
Trade: Painting Contractor
Send a message via AIM to Humble Abode
Water Damage
Can anyone reccomend a good latex primer for covering water damage, besides Bullseye 123?
Humble Abode is offline
Old 03-24-2005, 09:18 AM   #2
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: Water Damage
Not too keen on using water-based for water stains. I have used Zinsser's GARDZ on occasion and it worked, but there were only small spots. The HD says Kilz2 will cover water stains, but....it is HD after all. Kilz2 is worthless IMO.
Per a search on Google, click here. Scroll down to CIL Professional Interior/Exterior 100% Acrylic Stain Bloc Primer Sealer. Never heard of it, but who knows, it might be in your neck of the woods.
ProWallGuy is offline
Old 03-24-2005, 06:35 PM   #3
Exroadog's Avatar
Trade: paint
Re: Water Damage
BM Freshstart
Exroadog is offline
Old 03-24-2005, 09:00 PM   #4
Painting Contractor
Re: Water Damage
The reason I wanted to use a water based is because it is 7000 square feet and if I use an oil on the water damage I have to use an oil on the whole job, and I prefer water based. As far as I know, and correct me if I'm wrong, it isn't a good idea to use a oil primer with a water topcoat.
Yea I'm not a big fan of the Kilz either.
Thanks I'll check into both products
Old 03-24-2005, 09:40 PM   #5
George Z's Avatar
Re: Water Damage
You can use oil based or shellac based primer on waterstains only
and follow up with latex. If you are only using one finish coat, you
might have some flashing. Use an over all primer after your spot-prime
or two coats of finish. You can also use latex after an oil primer.
Before the acrylic super adherent primers, oil primers were used
all the time for oil to latex conversion.
George Z is offline
Old 03-24-2005, 09:42 PM   #6
ProWallGuy's Avatar
Re: Water Damage
I would say it depends on the substrate and specs to choose good primer/finish combo. On exterior wood, where stuff flexes and moves with temp. change, go with oil/oil or water/water system. Interior and metals are more forgiving. Whats it going on?
Old 03-24-2005, 09:42 PM   #7
Teetorbilt's Avatar
Re: Water Damage
You may want to look into Zinsser B-I-N. It's shellac based and quick dry. I use lots of it and have had no problems with pain adherance. It's also good for sealing knots, cedar, redwood and as a primer/sealer for wallpaper.
Teetorbilt is offline
Old 03-24-2005, 10:06 PM   #8
Painting Contractor
Re: Water Damage
Whats it going on?
Interior plaster, very old. The problem that caused the damage has since been fixed, obviously, or I wouldn't be painting it.
Old 03-24-2005, 10:17 PM   #9
Dripless
Dale's Avatar
Trade: Painting and exterior wood care
Re: Water Damage
.."no problems with pain adherance."
I know the feelin'...lol.
Dale is offline
Old 03-24-2005, 10:19 PM   #10
ProWallGuy's Avatar
Re: Water Damage
If the stains aren't too dark, I'd try to wash them down with a bleach solution (if feasible), and coat it with B.M. Freshstart or Perter's BlankIt. Both are acrylic, and have an ammonia odor, but cover well.
Old 03-24-2005, 10:34 PM   #11
Painting Contractor
Re: Water Damage
cool. yea I never even thought to wash it down. Thats a good idea.
Old 03-24-2005, 10:56 PM   #12
ProWallGuy's Avatar
Re: Water Damage
If I considered using the water-based primer, I would definitely test drive a spot as soon as possible. Put a quick swipe of primer and finish over a stain, to see if it will bleed or not after drying, before I did the whole project.
Old 03-25-2005, 06:50 AM   #13
Exroadog's Avatar
Trade: paint
Re: Water Damage
"very old interior plaster" if it has never been painted, your best off with oil primer. Then finish with latex.
Exroadog is offline
Old 03-25-2005, 08:27 AM   #14
Painting Contractor
Re: Water Damage
It's been painted before, probably several times. There's no bonding issues with oil to latex?
There is also a 3'x2' hole that needs to be repaired. I was thinking a masonry primer after it is patched, is that even nesisary?
Old 03-25-2005, 08:48 PM   #15
ProWallGuy's Avatar
Re: Water Damage
No bonding issues with oil to latex.
Masonry primer would be optimum, but not entirely necessary. If the new plaster isn't extremely porous, then just double-coat it with whatever primer you are using.
Old 03-25-2005, 11:00 PM   #16
Dripless
Dale's Avatar
Re: Water Damage
If you're going to use plaster for a patch use the right primer and make sure its dry enough to paint. Old plaster formulations used to need anywhere from a week or two up to a month to dry.
Dale is offline
Old 03-27-2005, 02:31 AM   #17
paintr56's Avatar
Trade: paint contractor since 1974
Re: Water Damage
Gripper from ICI. Make sure and let it cure twenty four hours before top coating.
Jim Bunton
paintr56 is offline
Hot Water Joewho Plumbing 13 11-17-2006 02:39 PM
Carpet Water Damage tribe_fan Flooring 6 08-08-2006 09:18 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
Water Damage Dusty Remodeling 4 01-29-2006 10:10 PM
