Wallpaper Removal
Old 04-29-2006, 08:44 PM   #21
747's Avatar
Re: Wallpaper Removal
I would do it slickshift ways. Go rent a wallpaper steamer. Score the wallpaper to make little holes in it and steam it loose. Once you get the paper off go with this.http://www.zinsser.com/product_detail.asp?ProductID=27
747 is offline
Old 04-30-2006, 12:37 AM   #22
Woz the Painter's Avatar
747... I've always thought of a wallpaper steamer as a personal sauna, in my encounters with them, they suck, but some people might like a two for one!
Woz the Painter is offline
Old 04-30-2006, 01:09 AM   #23
747's Avatar
I rented one once and the wallpaper just pealed off actually in sheets. No problem it way gravey all the way.I thought it worked excellent. But i did have to buy one of those hand held scoring tools to run over the wallpaper and make the holes in it. It was a little bit steamy but i new it wasn't going to be a clean job.
747 is offline
Old 04-30-2006, 01:25 AM   #24
Wow 747 your an airline pilot? how come you didn't get in on the airline security thread?
Old 04-30-2006, 03:03 AM   #25
747's Avatar
I didn't see it.
747 is offline
Old 03-20-2007, 10:30 PM   #26
lornmastro's Avatar
Trade: interior paint contractor and window treatment workroom
bringing this back to the top...great thread
lornmastro is offline
Old 03-21-2007, 04:36 PM   #27
Custom Painter
Red Canary's Avatar
Trade: Custom Painter
Never heard of the concoction of dif, vinegar . . . etc. Would like to try the fabric softener recipe.
I score the paper, wet it with warm water, spray with dif and warm water, let stand, spray again, let sit again (less time than the first) and then remove, re-wetting as necessary with dif.
Then, wash the wall with TSP phosphate free. Then, I usually wash the walls again with a dif mixture, then another wash with TSP--gets all the glue almost all the time.
Sherwin Williams makes a primer/sizing product (can't think of the name off the top of my head right now) and this works great--it's latex, also.
After priming, I spackle, etc., then spot-prime over repair areas with the same primer and/or primer/sizer.
Red Canary is offline
Old 11-25-2008, 09:02 AM   #28
Traditions2's Avatar
Trade: painting and refinishing
I'm getting ready to paint over wallper removed wall. I've always used oil. Sherwin told me to use latex problock. ANyone use this? Good results.>?
Traditions2 is offline
Old 11-25-2008, 08:55 PM   #29
A bit abrasive.
WisePainter's Avatar
I use a mix of hot water mixed up with Krud Kutter in a pump sprayer after I run a paper tiger lightly over the surface.
It usually takes 3 passes with the sprayer over a 30 minute period.
After the paper is off I use an alkyd primer to prevent the left over wallpaper adhesive from reconstituting when a latex primer/top coat is applied.
I have 50 cheap beach towels that I place at the baseboard to mop up any run off.
Works for me.
My advice: Hire a real painter to do it.
WisePainter is offline
Wallpaper removal and Gardz. gideond Painting & Finish Work 18 12-11-2007 10:34 PM
Wallpaper Removal Red Canary Painting & Finish Work 33 03-21-2007 03:24 PM
pricing wallpaper removal lornmastro Painting & Finish Work 23 09-21-2006 09:40 PM
Wallpaper Removal zcrazypainter Wallpaper 4 07-23-2006 07:18 PM
wallpaper removal question rocco Wallpaper 3 01-30-2006 03:19 PM
