Trade: i just need help with wallpaper removal
Wallpaper Help!!!!!!!
I had a difficult time removing the wallaper from my hallway walls. The wallpaper was 3 layers thick and put directly on the drywall. when I took the wallpaper off (i used diff and a paper tiger) it seems like the first layer of drywall came off also. I have sanded the drywall down as much as i can but when i went to apply the joint compund the drywall was coming off into the compound. Also the section that I did, after the compound dried..it started bubbling all over.....What can I do to fix this.
I am not going to re-apply wallpaper I just want to be able to paint the walls!! |
#2 | |
Pro Painter
Re: Wallpaper Help!!!!!!!
You need to seal the drywall....Zinsser's Guardz. Then skim, sand, prime, and paint.
#3 | |
...jammin
Trade: Rock Disciple
Yeah you'll need to Gardz it, skim coat it with joint compound, sand it, then prime it before painting
Signature Quote Quote:
Back from the dead...
Trade: Paperhanger/Painter
Yep, what they said is correct.
Seeing you are a homeowner, and not a contractor, please post other questions at our sister-site, DIY Chatroom. Many of the pros here answer the questions over there. TIA |
| Pricing out hanging wallpaper | gary lee | Wallpaper | 51 | 10-28-2009 07:16 PM |
| wallpaper removal | lornmastro | Painting & Finish Work | 28 | 11-25-2008 08:55 PM |
| Wallpaper Removal | Red Canary | Painting & Finish Work | 33 | 03-21-2007 03:24 PM |
| wallpaper!!!! | manders44070 | Wallpaper | 4 | 03-04-2006 01:28 PM |
| wallpaper removal question | rocco | Wallpaper | 3 | 01-30-2006 03:19 PM |
