Trade: Residential Repair & Remodeling
Wallpaper And Guardz
Have a friend that is remodeling and has wallpaper 4 feet up from floor. Maybe 20-30 lineal feet that needs removal or gardz My painter says that it is not necessary to remove the paper. He is going to apply Gardz,skim coat the entire wall, texture with skip trial (stucco look). Is this going to work? The paper is very well adhered to walls. Current texture is "knock down".
Any advice? |
#2 | |
...jammin
Trade: Rock Disciple
Re: Wallpaper And Guardz
You reaaaallly want to remove that wallpaper
The only time you want to go over it, is when it's direct to rock -no paint/primer- and removing it is actually bringing down the sheetrock
Signature Quote Quote:
Trade: paint contractor since 1974
I agree with Slick. You are adding a lot more weight then that wallpaper paste was ever meant to hold. If it fails you will have a real mess to deal with.
Jim Bunton |
turning houses into homes
Trade: Wallcovering Installation
and down the road when it DOES fail and some poor sucka (like me) has to remove it, you and your family for three generations will be cursed.
Seriously, what's the problem with removing? If prepared correctly under, it's a peice of cake ..... if you know what you are doing. If I had a painter that advised not to strip such a small amount but wanted to Gardz over it, I would wonder about his professionalism. (Just my opinion) And BTW, the product is spelled Gardz - no biggie, just a pet peeve of mine. |
MFWIC
Trade: house painter
It is BEST to remove it.
If the painter will guarantee his quickie, present the matter to the client. Do they want to save $500 ? I would go over it, but no guarantee... It's only a quickie cheapo fix. A sheetrock surface will only support so much. Here it is again... quality, service, and price. Is it best to keep it simple, or add liability and reputation to the KISS ? r |
Trade: Painting Contractor
i agree remove, then skim.
Sean |
#7 | |
Trade: Painter, plaster repair
Re: Wallpaper And GuardzQuote:
Normally I will remove the wall paper, but when I was removing it it tore off the paper on the drywall, making a holy mess. Gardz is good.
http://thewallfixer.21publish.com/ |
Information is only good if you use it.
I gave my buddy everyones comments and working experiences with and with out Gardz. He goes to HD they don't have it so they sell him oil based Killz. I'll update the progress. On a side not they decided to stay with a knock down texture to match the rest. Not that it will matter much now but should he have primed the entire wall not affected by the paper?
I have used oil based Kilz with no problem so far. But I do try to remove all the paper I can. Can't find Gardz here. I do see Bin shellac based primer at lowe's.
Trade: Residential Remodeling
To get Gardz, you have to go to a real paint store.
#11 | |
Trade: Wallpaper Whisperer
Having said that, I prefer the original drywall repair clear (DRC), Draw Tite, which spawned all the imitators like Gardz. But Gardz will do the trick for you. |
#12 | |
Txbassboy, PLEASE before your "painter" goes ahead with his "plan" have him sign an absolute iron clad acceptance of responsibility for any failure within the next five years. It may make him think perhaps the over 100 years of accumulated knowledge here may know better. |
Trade: Painter
Here in IL, they do have gardz at the local HD.
Sent the customers to get some, with instructions to call me if they tried to sell them kilz. Guess what? They tried to sell them kilz. HD had it in gallons only and the customer had to find a more experienced salesperson to get it. Probably in the wallpaper dept. Last edited by Joewho; 11-21-2007 at 09:24 PM. |
REGAL PAINTING
Trade: painting contractor
gardz is for damaged drywall where the paper of the dywall has been damaged, not for painting over wallpaper I thought.
#15 | ||
...jammin
2) Original Kilz is a great product, but it's a stain blocker not a high performance penetrating sealer used for sealing uncoated wallpaper before painting...so once again "the guy at home depot said..." ruins another home reno project If it actually works, the chance of later failure is high If it actually lasts for a few years, I'd be shocked...but I suppose it could happen...but don't worry, the person doing the repaint will get hosed 3) Tell your friend the painter to get his azz to a Paint Store and ask them what they recommend before doing anymore projects
#16 | |
...jammin
Stop listening to the painter who buys his paint and gets his advice from the "guy at home depot"
#17 | |
YES, that is what it is being sold primarily for, hence the designation of Drywall Repair Clear (DRC) a term I believe coined by my friend Jim Parodi (Parodi on Paperhanging in PWC magazine). Now, Mr Sticky Shorts may know the history since he buys Draw-Tite (the original DRC) direct from Scotch Paint, but if I remember correctly, Draw-tite was formulated to seal concrete. A bunch of paper hangers out in LA noticed that it would not only help seal and lock down torn drywall, but also would penetrate "builders flat" so that we could hang on top of it. (Please, you all, do not use builders flat, wallpaper WILL YANK IT RIGHT OFF THE WALL). Draw-tite will also penetrate PAPER-paper and assist in it being locked down to the substrate. It will NOT penetrate a vinyl or vinyl coated paper. Draw-tite is also good for sealing joint compound and other porous substances. Now, a few years ago, Zinsser approached Charles Mc(something- head of Scotch Paint) and offered him a good sum to buy the formula. Charles (a crusty young bat) told Zinsser to F*UCK off. After some unsavory behavior on the big Z's part to try to corner the market on the resin used, the big Z reverse engineered Draw-Tite and made their own product, Gardz. BUT, in order not to infringe on the patent, they make it with less of the important resin. I.e., they make "Draw-tite lite". Now, don't get me wrong, Gardz does a great job, I use it myself (just TRY to buy Draw-tite in New England !), but Draw-Tite is a BETTER product. Some people are mixing Gardz with 1-2-3 to get the best of both words. Some are mixing Gardz with Shieldz ("Shardz") again, for the best attributes of both. I've had a disastrous result mixing Gardz and 1-2-3. Luckily it was in my own house. This is a picture of me peeling it off the wall:
#18 | |
...jammin
"Best of Both Worlds" = Master of Neither
#19 |
[quote=Txbassboy;I gave my buddy everyones comments and working experiences with and with out Gardz. [U]He [/u]goes to HD they don't have it so they sell him oil based Killz.
I wasn't clear I guess. Friend buys the killz(in a hurry because drywall finishers are trying to mud over paper) He applys the killz on advice from HD. Actually, it's either HD or Lowes cant remember clearly now but they do sell Gardz but it was only in a quart. I actually did tell him though that the painter said it would probably be at a Benjamin Moore When I get a chance I'll get some pic just for kicks for everyone. |
