Vinyl Clad Windows - Interior Caulking
Old 07-26-2008, 12:41 PM   #1
artinall's Avatar
New vinyl windows ( < 2 yrs old) were installed in a new Ryan home. Double hung and fixed sections. About 30 of them all with a clean and consistent uncaulked line left between the innermost vinyl and drywall. Brick exterior.
Easy answer is for caulk, which I normally do.
But with the outside seam taken care of isn't this really a matter of aesthetics?
artinall is offline
Old 07-26-2008, 12:59 PM   #2
Re: Vinyl Clad Windows - Interior Caulking
Yes it is.
As are the third coat of drywall mud,
the paint, the interior doors.....
neolitic is offline
Old 07-26-2008, 01:04 PM   #3
Dan_Watson's Avatar
Yes, if water were to get in that far, it would compromise the drywall with or without the caulk there. Its just like caulk along trim.
Dan_Watson is offline
Old 07-26-2008, 06:05 PM   #4
artinall's Avatar
What about air exchange -- heat and ac loss?
Assuming the exterior is sealed, doesn't the drywall > stud > insulation sequence pretty much cover possible loss from the inside?
Then there's the idea that you can seal a house too tight, right?
artinall is offline
Old 07-26-2008, 08:08 PM   #5
Dan_Watson's Avatar
The interior calk should do nothing to stop air, or any energy exchange. It should be just cosmetic.
Old 07-26-2008, 11:37 PM   #6
Dmax Consulting
Dmax Consulting's Avatar
Trade: Paint Contractor
lol at neolitic's post
Dmax Consulting is offline
Old 07-27-2008, 03:34 AM   #7
Stewy's Avatar
Trade: home improvements and renovations
To alot of customers aesthetics is more inportant than efficientcy or practicallity so make it look nice too.
Stewy is online now
Old 07-30-2008, 12:29 AM   #8
artinall's Avatar
Will be left uncaulked. Thanks for the posts.
artinall is offline
Old 07-30-2008, 07:06 AM   #9
DeanV's Avatar
Trade: Painter
From the posts here, how could you come to the decision to leave it uncaulked? It needs to be caulked to be finished. It is the right way to do it.
DeanV is offline
Old 07-30-2008, 10:46 PM   #10
artinall's Avatar
It already has a finished look. It is so neat and even, a rare case. And easier to mask off. I don't see a reason to caulk, but I guess you would have to see them.
The vinyl track is actually fitted overtop the drywall, which is uncommon. Since it is normally butted up to it. They must have installed the 1/2 (outer) window in one step and gone back after the drywall was finished to install the other inner 1/2. Haven't seen done this way before.
artinall is offline
Old 07-31-2008, 11:06 PM   #11
capital city's Avatar
Trade: painting
I have no idea what this guy is talking about. Dont you use wood trim on the inside to finish the window? Not vinyl.
capital city is offline
Old 07-31-2008, 11:52 PM   #12
I think he's looking at drywalled
jambs with vinyl J-channel trim.
neolitic is offline
Old 08-01-2008, 09:44 AM   #13
artinall's Avatar
yes, I think so. With a finished look when left uncaulked. Thats the one.
artinall is offline
Replacement Vinyl windows Project53 Windows, Siding and Doors 61 03-23-2011 09:02 PM
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Vinyl Windows rayh78 Construction 3 05-04-2008 10:57 PM
sq.ft. price on vinyl replacement windows ch0mpie Windows, Siding and Doors 10 08-16-2006 11:22 PM
Brown vinyl windows skidmark845 Windows, Siding and Doors 8 05-31-2006 10:12 PM
