Vines On Stucco Walls
Old 02-12-2008, 12:19 PM   #1
Drywall & Painting Pro
Sir Mixalot's Avatar
Trade: Hang, Finish, Texture, Paint, and Repair.
I 'am going to be painting the exterior (stucco) of a large two story home.
I've already pressure washed and where ever these vines had grown up the wall the roots of the vines are still there. Previously on a one story home I used my Millwuakee heat gun and a wire brush and that worked great! But, that was just for a couple areas 8' high. This job has alot of these up to 20' high. Any ideas? Thanks.
Sir Mixalot is online now
Old 02-12-2008, 12:39 PM   #2
The Paintman
Thepaintman's Avatar
Trade: Painting contractor
Re: Vines On Stucco Walls
Been there, done that and hope I don't ever have to do it again especially at that height. We've used the procedures you have used and they worked for us. I hope someone steps up to bat with an easier method - I'll be checking back for responses. Lots of luck and work safe.
Jerry
Thepaintman is offline
Old 02-12-2008, 09:19 PM   #3
plazaman's Avatar
pressure wash with sandblast attachment?
plazaman is online now
Old 02-12-2008, 09:35 PM   #4
I tried the RED tip and then the YELLOW tip. They both took off the vine root and the stucco texture. The GREEN tip didn't touch it.
Old 02-14-2008, 08:30 AM   #5
Anybody got any tricks?
Or is the heat gun and wire brush the best option?
Old 02-14-2008, 11:28 AM   #6
Painting and landscaping
troym's Avatar
Trade: Painting and landscaping
Here is the tool that i use.
Makita 5 In. Disc Sander.
troym is offline
Old 02-17-2008, 12:25 PM   #7
Frankawitz's Avatar
I had a big job last year of a stucco repairs and the place had vines I use a tip that they call the Turbo tip. it's a zero tip that rotates it worked really good but it takes time to get them off but it worked pretty good.
Frankawitz is offline
Old 02-17-2008, 09:22 PM   #8
wjobert's Avatar
Trade: Sales/Ops Manag/General contractor
You have to burn them off-we do this all the time with(I don't know exact name), the larger pistol grip torch that attaches to a propane tank.
wjobert is offline
Old 03-18-2008, 04:24 PM   #9
I got rid of the vines. After the initial pressure wash, I came back about 2 weeks later and pressure washed them again w/ the green tip. I think they dried out after the 2 weeks, and came right off.
After 2nd washing
Primed
Painted
1 coat vs. 3 coat stucco finishing janrickey General Discussion 12 07-17-2011 11:22 AM
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 09:10 AM
Why Build ICF monsterconstruc Green Building 32 09-28-2008 11:48 PM
Small outbuilding 3 walls stucco one ? Team Scream Construction 28 11-06-2007 10:59 PM
