Very Rough Cedar Siding
Old 07-25-2006, 05:59 PM   #1
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Send a message via Yahoo to painterofeveryt
Normally I would spray (with an adjustable tip )and back brush,but this stuff is so hairy I think I will try to roll it after spraying with a 6 inch long 1 inch nap lambskin mini roller cover ....Any Thoughts ?
painterofeveryt is offline
Old 07-25-2006, 06:10 PM   #2
DeanV's Avatar
Trade: Painter
Re: Very Rough Cedar Siding
You might want to try sanding it quickly with 80 grit to knock some of that hair off, especially if it is new and unfinished (although it probably would not hurt even if it is finished). I ran a drywall sander with 80 grit on my extension pole around a hairy douglas fir overhang before priming.
DeanV is offline
Old 07-25-2006, 06:17 PM   #3
Jon F's Avatar
Trade: Log Home Services
What caused it to become so "hairy"? Pwashing?? Are you staining,Sstaining, or painting??
Jon F is offline
Old 07-25-2006, 06:18 PM   #4
Teetorbilt's Avatar
Cedar sands very easily although old paint can load paper rapidly if you try to go too fast. You are also going to have to prime with an oil or shellac based primer to prevent bleedthrough.
If the 'hair' is already locked down with paint, I'd spray.
Albert Einstein
Teetorbilt is offline
Old 07-25-2006, 06:21 PM   #5
painterofeverything
The hair is painted down (numerous coats,oil and water based coats)will be using grahams ceramic stain/flat house paint...thats what they call it,not me...waterborne product ,Thank you all for your advice
Old 07-25-2006, 07:14 PM   #6
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Yup, you can just give it a quick sand with the orbital or belt....since it's painted, you probably won't need more than 60-80 grit to knock off those splinters. Rough sawn boards are a real pain in the finger to caulk for painting sanding should help that and the spraying.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 07-26-2006, 09:48 AM   #7
Bah Humbug!
Grumpy's Avatar
Cedar should not be painted. The natural tanins (oils) in the wood don't play well with paint. Therefore solid stain is the preferred method of finishing cedar of any kind. I'm not painter but I've done alot of research into this because I install a good ammount of cedar siding and trim.
Grumpy is offline
Old 07-26-2006, 12:49 PM   #8
DeanV's Avatar
Trade: Painter
I would not use shellac for a large scale priming operation outside since it functions as a vapor barrier and moisture moving from the inside of the building out will cause it to peel. Also, it is probably to brittle for expansion/contraction. Save it for the knots only. Ditto to Grumpy on the stain, that is all I use on cedar, not sure if everyone elso uses the stains or goes for paint (btw the Graham's stain/paint is a true solid color stain, but I guess then label if for double duty as a flat paint because if you use a solid stain over a painted surface, guess what, solid stains will function like a flat paint.)
DeanV is offline
Old 07-26-2006, 01:08 PM   #9
painterofeverything
Dean have you used this grahams product? what did you think of it ? seems to go very fast for me.I love it!
Old 07-26-2006, 04:21 PM   #10
Pro Painter
AAPaint's Avatar
I agree whole heartedly. However, in the world of repaints cedar is often painted before we get to it. I would hope that any painter in his right mind would suggest a stain for cedar....to me it's a sin to cover up such beautiful wood.
-AAPaint
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 07-26-2006, 05:23 PM   #11
DeanV's Avatar
Trade: Painter
I use a lot of it on condo exteriors in the summer. Been using it for at least 5 years and so far, I am happy with it.
DeanV is offline
Cedar siding removal bid help haskl33 Windows, Siding and Doors 21 07-03-2009 12:55 PM
Products for cleaning cedar siding? rangie Painting & Finish Work 2 07-24-2007 04:34 PM
cedar siding backer question Home Serve Windows, Siding and Doors 7 04-26-2007 02:09 PM
OLD unprotected cedar siding DeanV Painting & Finish Work 4 11-13-2006 08:36 PM
Cedar siding question? XXL Hardscaper Windows, Siding and Doors 2 01-31-2006 02:50 PM
