Trade: Licensed Home Improvement Contractor
Using Sprayer As A Power Washer
Anyone ever do this? I need to power wash some siding and have an airless. Its like 2500 psi? reverse the tip and blow soapy water thru it. I dont want to ruin it tho.
Painting Contractor
Trade: Painting Contractor
Re: Using Sprayer As A Power Washer
I don't think I would, seems to me it would cause excessive wear on the pump. I'd just rent a PW if u need to.
If love is blind, why do they make Lingerie? |
painterofeverything
Really bad idea !!!!
Trade: EXTERIORS
I can't believe someone would ask that on here
i agree with every thing that was replied.
Sean |
Trade: Painting & Remodeling
"Stupid is as stupid does" For $300 you could have a basic model that would get you started so why bother trying it.
#7 | |
Professional Painter
Trade: Owner/Operator
Re: Using Sprayer As A Power WasherQuote:
Wouldn't do it Reason? My sprayer cost me $1000. When I need a power washer I rent one for $80 for the day. I'm sure this isn't outside of your budget Use the proper equipment before you don't have any that works Good luck
Rich |
Trade: Painter
I bought a Power washer for $300 bucks. Pays for itself in a couple of jobs.
Trade: Remodeling contractor
Good replies .......The right Tool for the job. Not just any tool.
Back in Maine Dubbin' Around Doin' good stuff ...... |
Easy does it Hudson..........if you don't ask, you don't learn...........
This forum is for sharing knowledge & experience. Don't get pissy about it.......
Trade: Painter
I don't know about using the sprayer as a washer, but if you do it, let us know how it works.
I'd worry about what the soaps might do to the seals. I'd also be in doubt of the power generated by painting tips. It might push 2500/lbs. but the tip won't work. Might just as well use a hose with a soap dispenser. It's still an interesting idea. Could you try it, just so we know what happens? |
Thanks tcleve..
Im not a painter so thats why I asked. I see other trades asking silly questions a lot on here about the stuff Im knowlegable about. I just dont post a reply,or I give them advice. Water seemed less damaging then latex. When you reverse the tip it puts out some pressure. And I dont mean using it as a pw 8 hours straight. |
Trade: Pain
Hey Oz that is a very good question and not at all silly (Sharron),it is do able and has been done. not with a airless tip reversed though.I have a graco gh433 oldie but goodie that can be converted to a pressure washer by just simply swapping out the displacement pump and using a pressure wash gun wand and tip and tada.chances are slim that you have a gh433 and the xtra displacement pump required to have that one two punch you are looking for in one airless spray system.btw i dont use mine anymore and am looking for a fair offer on mine with parts golore to go with it.
Deck Cleaner
Trade: Deck Cleaning, Staining, Restoration
It has the pressure but not the flow. It would take you ten years to do even a small project. If you replaced your seals with Vitons you could probably use it as chemical application pump on a small deck.
Trade: Painting Equipment
It's not a bad idea...how do you think they came up with the idea of a pressure washer ?
Graco still makes a air powered pump call the HYDRO-CAT. But now in the 21st century, you can rent or buy pressure washers cheap. So I agree with everybody else... |
habitual line stepper
I wouldn't waste my time with it since based on how it would spray, it wouldn't be strong enough to rinse and reach properly vs. a typical powerwasher. And there isn't anything wrong with asking questions. All good.
MFWIC
Trade: house painter
Ozzie, I'm glad to see you putting that college degree in engineering to work in the paint industry !
But did you notice, the fan, @ 2500psi can cut like a knife ? yet when you reverse the tip to hock out a booger all yah get is a fizzy stream ? The airless pump generates pressure, against the small hole in the tip. Direction of the tip, fore, or aft, determines application of the spray in a useful pattern. Either way, all you get is .5 to 1.5 gal per min from a $500 -$5000 airless pump. They make other machines for pressure washing. For $300 - $5000 you can generate 1500 - 4000psi, at a flow rate of 2.5Gpm to 8Gpm. Pressure washers generally speaking, function by flow, rather than PSI... Problem is, just like spraying paint, if ur angle of the dangle is incorrect, too close, or too far, bad things happen. If you are too close, with too much pressure, you will destroy wood, or even conrete ! Pressure washing is really, power washing. The work is done by flow, rather than pressure. But it gets more complicated, as painting has become. Chemicals rear their ugly head. Proper power washing is accomplished by suitable application of the appropriate chemical to the surface at a relatively LOW pressure. It is allowed to sit upon the surface in need of treatment for a period of time, then, is rinsed off by a higher, but minimum useful pressure to get the job done. You might speak to someone about pressure washing, first, or at least run a search on pressure washing to learn about the subject. I did. Believe me, it can be a complete and whole field of activity. LOT'S to learn about power washing! r |
#18 |
Trade: paint contractor since 1974
Many have given the right answer about flow and pressure. Even with the tip the right way you lose pressure very close to the gun at 12" it is a fine spray. I do not think the soap would harm the sprayer.
I just wanted to say don't worry about what you ask. I am one that has been in other rooms asking what were probably kindergarten questions and have come away with good advice. Jim |
#19 | |
Deck Cleaner
| Solar Power Industry Dead In California | w6ire | Electrical | 2 | 06-28-2007 09:57 AM |
| Power Outage Question? | Ron The Plumber | HVAC | 5 | 12-20-2006 09:42 AM |
| Water heater, elec., power surge problem ??? | tzzzz216 | Plumbing | 8 | 11-05-2006 10:24 PM |
| power washer help. | RYANINMICHIGAN | Tools & Equipment | 1 | 05-01-2006 04:06 PM |
| LARGE power washer for sale | fez-head | Contractor Swap | 0 | 08-18-2005 09:26 PM |
