Trade: painter
Using HVLP Indoor
I am working on priming then painting built in wall shelving bookcase. I am taking doors off and spraying in garage. Should I brush or spray the built in portion. Will it cause too much overspray.
Trade: Painting Contractor
Re: Using HVLP Indoor
Depends, how big is the unit? If it is small it would not save much time. If it is large than yeah spray that sucker down. HVLP's have a greatly reduced amount of overspray, however they do still produce it. Mask off the walls around the unit.
Sean |
A bit abrasive.
I mask all surfaces that are not going to receive lacquer (within 3 ft. of the substrate being lacquered) then dial down my 395 to about half and use a 311 green fine finish tip.
An HVLP is a great choice if the HO will be around watching you work, it reminds them of auto body shops. Who wouldn't want their furniture finishes to look like a Ferrari?
My advice: Hire a real painter to do it. |
Trade: Painter
It may just be me, but I feel like HVLP sends more paint airborne that can drift through the house. Airless definitely puts out more paint by far, but it does not seem to carry as far to me.
| fill in an indoor pool? | tersh | Pool Construction & Enclosures | 8 | 01-10-2009 02:07 PM |
| Air Compressor or Turbine for HVLP? | Rob Vinnedge | Painting & Finish Work | 5 | 11-05-2008 05:20 PM |
| done research but I need help with purchasing HVLP set-up, latex work mostly | jordanski | Painting & Finish Work | 9 | 04-24-2007 06:03 AM |
| All right I went today and finally broke down and bought an HVLP | Dorman Painting | Painting & Finish Work | 18 | 04-15-2007 01:39 PM |
| Indoor air quality | woodmagman | Green Building | 11 | 04-04-2007 10:13 PM |
