Using Frog Tape On ˝" Baseboards To Get A Straight Line.
Old 12-09-2017, 03:29 PM   #1
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
Rewards Points: 268
So... long story short, our painter is having a really tough time making this baseboard look good. He has experience, but is still learning.
The wall is in and out, and the baseboard obviously follows the contour of the wall. However no matter what he does, it does not look right.
The base board is a Char grey, and the walls are a light grey, so there is a huge contrast in colour. The wall is about 30 feet long, and is the main wall that people see when they come in the door, as it is a grand style entrance.
Does anyone have any suggestions on how to make this look uniform.
Thanks
Profit is NOT a dirty word....Cheap is....
AARC Drywall is offline
Old 12-09-2017, 03:34 PM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,239
Re: Using Frog Tape On ˝" Baseboards To Get A Straight Line.
Run the baseboard paint up onto the wall a bit. Forget tape, just keep the 3" brush moving. Or redo the baseboard.
MarkJames is online now
Old 12-09-2017, 03:35 PM   #3
avenge's Avatar
Rewards Points: 2,856
If the walls are effed up how is the painter supposed to give the optical illusion that they aren't?
avenge is offline
The Following 3 Users Say Thank You to avenge For This Useful Post:
kirkdc (12-09-2017), MarkJames (12-09-2017), sparehair (01-08-2018)
Old 12-09-2017, 03:38 PM   #4
MarkJames's Avatar
Paint wobbles that counter the wall wobbles.
Old 12-09-2017, 04:05 PM   #5
hdavis's Avatar
Rewards Points: 729
You'll see this type of issue a lot if the caulk line is titled at an angle.
Hand cutting to get a good looking paint job on the baseboard is both the best and most skilled approach. If he has problems with getting the line wavy, It's probably easiest to use something like a towel rod as a standoff and guide for his hand. Slower, but you can get a phenomenal line that way. It's a pinstriper technique.
hdavis is online now
SmallTownGuy (12-09-2017)
Old 12-09-2017, 04:31 PM   #6
avenge's Avatar
Real painters don't use tape.
avenge is offline
The Following 6 Users Say Thank You to avenge For This Useful Post:
DaVinciRemodel (12-09-2017), hdavis (12-09-2017), Jay hole (12-09-2017), SmallTownGuy (12-09-2017), sparehair (01-08-2018), SuperiorHIP (12-14-2017)
Old 12-09-2017, 06:03 PM   #7
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 24
Dave Simms, a very talented old-style hand signpainter and friend of my dad's would use a special ball-end rod for a pinstriping guide as you state. 1993/R.I.P.
P42003 is offline
The Following 2 Users Say Thank You to P42003 For This Useful Post:
hdavis (12-09-2017), sparehair (01-08-2018)
Old 12-09-2017, 06:24 PM   #8
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,796
The wall is whacked and jacked.
You're pretty limited to what ya can do. It ain't the painters fault nor is it his responsibilty to pull rabbits out of his hats and cover up someone elses crappy work.
kirkdc is offline
Old 12-09-2017, 07:01 PM   #9
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 812
As I’ve said before: I’m a really good carpenter… My painter makes me look like a great carpenter.
No tape – free hand cut.
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
The Following User Says Thank You to DaVinciRemodel For This Useful Post:
JenniferTemple (01-09-2018)
Old 12-13-2017, 08:02 AM   #10
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
I was a sign painter for 28 years so walls are no problem. I seldom use tape but sometimes it is faster. I had an art background so lettering came quickly. It does take practice though. Look where you're going, not where you've been.
RangoWA is offline
The Following 2 Users Say Thank You to RangoWA For This Useful Post:
hdavis (12-13-2017), sparehair (01-08-2018)
Old 12-13-2017, 08:31 PM   #11
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,632
That's the same thing that I tell people who want to watch the blade on a circular saw and not the guide.
Home Designer Series Software
B.Johnson is offline
Old 12-14-2017, 05:50 AM   #12
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,516
Well I guess that's the difference between the front and back of the blade..
Sent from my SM-G930W8 using Tapatalk
heavy_d is offline
Old 12-14-2017, 02:23 PM   #13
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,574
Originally Posted by AARC Drywall View Post
So... long story short, our painter is having a really tough time making this baseboard look good. He has experience, but is still learning...
Hopefully he's not the fall guy for all this... "It's the Painter's Fault"
a) but the real answer: tear off the base / casings and then the drywall in the affected sections.
b) shim the walls level (or possibly coarse grit wheel on an angle grinder to help level certain spots) - I just did this recently.
c) put all back together this time straight, planning with your existing flooring
d) now call back your painter to give him a fair shot.
Other than that, you could install a modification, like a framed base shelf unit if the room could take it (balance, etc)
Or bust out the widest taping blade ever seen
artinall is offline
Old 12-14-2017, 04:35 PM   #14
hdavis's Avatar
Rewards Points: 729
DIY tip, in case caslon is reading.
You can use your painter tool (or something similar) to create a slight groove in a surface. You can cut to the groove easier than cutting without the groove.
Old 12-14-2017, 09:07 PM   #15
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,358
Run into a similar issue frequently when the wall/ceiling angle is 45 degrees, those lines can be really wonky and you just have to make your own straight line.
SuperiorHIP is offline
The Following User Says Thank You to SuperiorHIP For This Useful Post:
hdavis (12-14-2017)
Old 12-15-2017, 06:55 AM   #16
artinall's Avatar
Previously more common in years past on the wall/ceiling corner particularly with stomps. Much cleaner. I'm a big fan. Until the wavy gen hit.
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
hdavis (12-15-2017)
Basement Wall Construction at Property Line PDX General Discussion 17 09-05-2017 10:17 AM
Concrete Line pump truck Builders Inc. Concrete & Paving 8 05-14-2015 12:18 AM
18 inch rollers and Tape Question dwbrooks Painting & Finish Work 88 09-01-2014 09:30 PM
Posts not in a straight line trctimberworks Decks & Fencing 35 07-08-2011 06:10 PM
