Old 02-19-2008, 10:54 AM   #1
Unwanted "Crackle" Effect!
We are re-doing a room for a good client, including new drywall on the ceiling. My guy was trying to be fast, and decided to spray KILZ oil-based (don't ask) as a primer. He waited the 4 hours required (on the can) and sprayed latex ceiling flat over the prime coat.
Returning the next day, we found that the paint had crackled all over, due (I think) to the fact that the KILZ was not fully cured before he sprayed the ceiling flat, and maybe because his applacation rate on the ceiling flat was a bit heavy, as well.
I am considering sanding and skimming as needed, re-priming and painting with rollers, but wanted to see if any real painters can offer anything that will prevent this becoming more of an awcrap than it already is. Luckily, client is fine, but who wants to test that further?
John Pride is offline   Reply With Quote
Old 02-19-2008, 12:38 PM   #2
Trade: 26 yrs experience in the painting business mid/se michigan
I would pole sand it, apply a coat of peel stop by zinsser then finish with ceiling paint, ps do not use oil on bare drywall in the future
mrpaintguy is offline   Reply With Quote
Old 02-19-2008, 02:00 PM   #3
You know, I knew that, and he knew to ask, since we've never...but that's all soon-to-be history, of course. Never hurts to humble a working man, I suppose! I appreciate the information, mrpaintguy. We will do just that. JP
Plywood direction effect on floor bounce over I-Joist personalt Framing 25 12-31-2008 05:28 PM
Your opinion on ceiling color for visually raising or lowering effect Mike Finley Painting & Finish Work 29 11-29-2006 02:33 AM
Milwaukee 18V combo kit unwanted christmas present cumminsdsl Contractor Swap 1 01-09-2006 08:10 PM
