Unfinished Concrete Deck
Old 04-24-2004, 09:52 AM   #1
Guest
Guest
Guest's Avatar
Posts: n/a
What kind of paint would you recommend? The deck is adjacent to a pool and I live in Tampa Florida.
Old 04-24-2004, 10:34 AM   #2
Teetorbilt's Avatar
Re: Unfinished Concrete Deck
Personally, I prefer CoolDeck. You could try a stain. If your heart is set on paint there are lots of them out there just be careful as many of them are slick and you may need to add nonskid. You don't want anyone coming out of the pool to crash and burn.
Teetorbilt is offline
Old 04-24-2004, 11:13 AM   #3
Guest
Guest
Guest's Avatar
Posts: n/a
What about Porter Paints Concrete Acryllic Paints? Have you had any experience with Porter?
Old 04-26-2004, 08:10 PM   #4
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Hi- Your best bet if you are doing this yourself would be a concrete stain. They are formulated specifically for concrete and to hold up around the pool. Make sure you etch the concrete before applying any product to assure proper adhesion. Also you can add silica sand to the stain for the skid resistance. The paint stores carry this. Just make sure to do all the steps the manufacturer recommends and you will have no problems. I am a contractor in Tampa and we do a lot of repaints for Kool Deck. As far as Porter, haven't tried any of their products yet. So couldn't help ya there. And since I just found this board last week and still have to register, I'm not sure if I can say specific products for you to use. But good luck!
Old 04-26-2004, 09:43 PM   #5
Teetorbilt's Avatar
This is not something that I do a lot of, I do it most often for my own use (shop floors). I like the stains because they penetrate and won't chip or peel like paints or even epoxy coatings. I have never found anything else that will stand up to the abuse that I give it.
The majority of my tools are the old, cast iron versions and are slid around on the floor. Carts and dollies are on steel wheels for less rolling resistance, they are frequently loaded with thousands of pounds. With stain, the wheels initially leave a white streak that soon disappears with foot traffic, everything else that I have tried has been destroyed. Another plus is that it does not alter the surface. A properly poured slab should not be slick, many surface coatings seal, fill and level the surface making non-skid a requirement.
Old 04-27-2004, 08:52 AM   #6
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
My vote is for the stain(alkyd) also. :Thumbs:
ProWallGuy is offline
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Correect Deck ?'s Robert and others IHI Decks & Fencing 9 05-21-2008 10:45 PM
Cedar Deck Prep Problems Larman Painting & Finish Work 2 05-04-2007 05:31 PM
Concrete Deck Joseph Azar Roofing 10 07-18-2006 07:49 AM
