Old 06-07-2009, 10:48 PM   #1
Trade: carpenter/ handyman
Tung Oil
I used Tung Oil on a birch cabinet I built. It was stained with a water based walnut. I applied two coats of Tung oil on it & then about 20 hrs later I popped it in my van & went to church this morning with the intent of installing it afterwards. The cabinet was only in the van a few hours & my van is pretty well insulated, but when I checked on it after church it appeared to have leporacy. It had large dry spots everywhere on it. Just a few hours earlier it looked great.
I postphoned the appointment with my customer & took the cabinet back home to work it over. I wiped down the spots with mineral spirits & reapplied the Tung oil & it appears to be alright now.
Does anyone here know why this happened?
Steve
stp57 is offline   Reply With Quote
Old 06-07-2009, 10:54 PM   #2
Steve
"It was stained with a water based walnut."
neolitic is offline   Reply With Quote
Old 06-08-2009, 07:30 AM   #3
Robie's Avatar
Trade: Cabinetmaker
A lot of finishing oils will bleed for some time after applied. It's excess oil coming from the pores. All you can do is keep on wiping it and it eventually will dry up and stop oozing. The warm van probably helped promote the process.
"Don't tread on me"
Robie is offline   Reply With Quote
Old 06-08-2009, 08:16 AM   #4
Thanks Robie,
It looks great today after a recoating, so you hit it on the head. I did forget to mention that I used a small amount of Japan drier on the previous coat to speed up the dry time. Maybe I didn't mix it in good enough?
Steve
Neo,
Water based stain wasn't the problem. Actually, outside of dye, it is pretty good at doing touch up through the oil finish.
Old 06-08-2009, 08:27 AM   #5
Lack Of All Trades
Darwin's Avatar
Trade: Professional handyman services
Steve
Sounds like the cabinet drew available moisture into the wood. Some areas were drier than others.
who dat is?
Darwin is offline   Reply With Quote
Tung Oil C.C.R. Flooring 18 06-08-2009 11:21 PM
What type of Non toxic Putty with work on wood floors and accept Tung oil Stain? refinisher Flooring 1 01-16-2009 05:29 PM
pros and cons of wood floor finishes klucrezi Flooring 8 11-13-2008 09:53 PM
Tung Oil Floors tthomas Flooring 3 08-15-2008 02:57 PM
Cider press finish. gideond Painting & Finish Work 7 03-08-2008 10:42 AM
