Trouble With Roller Lines Using 18" Wooster
Old 12-28-2007, 09:21 PM   #1
KJLinden2002's Avatar
Trade: Painting, Siding and Remodeling
I'm currently painting a new Pamida store and am repainting it because of severe roller lines. The walls are under critical light that consist of florescent lighting right above all surfaces. The walls are also new construction, which shouldn't matter cause I primed them and everything was blocked out. And they are all about 14' tall by 150' long. When I stand about five feet away it looks perfect. However, if I look down the wall I see a lot of angular sheen where the rollers were.
I used:
SW high hold out primer
SW eggshell Pro-Mar 400
Wooster 18" roller frame
I used the second time:
SW low sheen Pro-Mar 200
The second time will probably be my finished coat. It looks pretty good. However, one of the walls where there is a lot of lighting, still doesn't look all that good. I'm unhappy with the job and am curious:
What do you guys think of the Pro-Mar on bigger walls?
What do you guys think of the Pro-Mar under critical lighting?
What do you guys think of the Pro-Mar in higher sheens?
Finally, how about the Wooster roller frame? I love it but could it be causing my roller marks?
KJLinden2002 is offline
Old 12-28-2007, 11:09 PM   #2
habitual line stepper
DPainting's Avatar
Re: Trouble With Roller Lines Using 18" Wooster
I found that any time you have to run a sheen, other than flat, down a long stretch of wall under alot of lighting you will have a consistency issue if you stop between applying(i.e. lunch or break). As for the 18 inch roller, it's heavy and difficult to keep it even especially if you have to run it up 14 feet of wall. Basically you have a tough job to keep it even. Is it possible to spray it and back roll to get an even amount of paint on the walls? I honestly don't know what else you'd do to avoid any roller lines down a long wall of 150'. Good luck!
DPainting is offline
Old 12-28-2007, 11:10 PM   #3
...jammin
slickshift's Avatar
Trade: Rock Disciple
1)
Poor quality paint
(I can't say for Pro Mar, don't recall using it)
2)
Poor quality sleeves
(You don't say what sleeves you are using)
3)
Poor technique
(usually trying to 'squeeze' out the paint rather than applying it)
Defective or badly designed frame is certainly possible but not likely
More likely its how it's used (technique issue)
Signature Quote
slickshift is offline
Old 12-28-2007, 11:19 PM   #4
As I recall I used a poly and a soft woven roller cover. Maybe the poly didn't work well with the sheen paint. Also, regarding the spraying question, I did try to spray and back-roll the first time. Maybe I just didn't apply enough paint. I did have my ultra 600 up full blast with a two foot tip on an extension. I tried a level three finish (two coats of paint) then had to try a level 4 (primer then paint).
Another question I would like answered is, can't you just spray a surface and that be your final coat. I haven't sprayed much interior other than air assisted and trim. I do know that when spraying vehicles that the spray finish is your final finish. Is it possible to hook an airless gun up and just keep an even spray the entire way. If not, I assume you can at least do it for primer?
Old 12-28-2007, 11:47 PM   #5
...jammin
slickshift's Avatar
Many different qualities of these, but a true woven is in the right direction
Pro- or Super -Dooz Wooster maybe?
50/50 or wool would be better
Or Purdy White Dove if they come in 18s...not sure they do
If you had it up to full pressure, there's another issue
The tip will only allow a certain amount of paint through, upping the pressure won't help (if you are having other issues)
Signature Quote
Old 12-29-2007, 08:15 AM   #6
plazaman's Avatar
KJ - It is recommend to spray & back roll drywall 1) to stipple to wall for touchups, 2) Work the product better into the drywall, i dunno but some say without backroll, the product atually "floats" on the wall.
Im doing a flip house right now where we sprayed all walls with primer without backroll a thing. These are all painted plaster walls though
plazaman is offline
Old 12-29-2007, 09:22 AM   #7
johnthepainter
johnthepainter's Avatar
Trade: painting contractor
id add a few pints of water per 5 for a long run like that,,,,itll lay down better,,,,,and dont squeeze it out so much,,,,thats how your getting the snail trails
www.johnthepainter.com
johnthepainter is offline
Old 12-29-2007, 09:05 PM   #8
plazaman's Avatar
why not use one of those latex paint additives ?
plazaman is offline
Old 12-29-2007, 09:16 PM   #9
Side Effects May Vary
ModernStyle's Avatar
Trade: Professional Painting
If you already rolled a stipple onto the surface of the wall then I wouldnt be afraid of spraying an even coat across the whole thing and not back rolling it. Just set your pressure accordingly with your tip size so it doesnt line.
ModernStyle is offline
Old 12-30-2007, 03:18 PM   #10
Joewho's Avatar
Trade: Painter
What size nap on that 18" bad boy?
Are the walls studded at 16" on center? Are you sure what you're seeing are roller marks?
What I'm getting at is, with a short nap, really wide roller, it will not fill in the dips evenly. You can bet that there are going to be dips unless each and every stud is exacly straight with all the others. New construction is likely two coats of mud, NOT floated out far enough to make the wall perfectly flat.
A 3/4 nap roller will help, using light pressure on the last strokes.
Pro-mar 200 in any sheen will be the least worry. Of course, flat will always look better.
If what you are seeing IS roller tracks, then it's just a matter of using more care laying out the final strokes.
Joewho is offline
Old 12-31-2007, 01:13 PM   #11
Dorman Painting's Avatar
Trade: Painting Contractor
Here's a pointer for ya, DON'T use 18 inch rollers, they're garbage. Take a little more time and use the old nine inch rollers. The 18's almost always leave holidays and IMO, most people can't handle them for a full day. I don't allow them on any of my jobs.
Dorman Painting is offline
Old 12-31-2007, 02:53 PM   #12
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Send a message via Yahoo to painterofeveryt
HMMMM, not sure I agree with this post,how can any tool be garbage ? is it not more the user or is it always the tool? I mean try using a great quality lambskin 3/4 inch nap and tell me it's junk....
painterofeveryt is offline
Old 12-31-2007, 04:26 PM   #13
If I didn't use 18" rollers we would be there all day. I used a 1/2" nap and that might have been some of the cause. Also, we were really careful in laying the paint on. We even went so far as used all down strokes so the paint would stipple the same direction. We also, didn't roll over already drying paint.
As far as the 18" roller goes, I don't see any other way to do a commercial job. The Wooster roller frame is AWSOME and rolls smoothly. I used it on a 14' pole extended to about 10 for 10 hours. While it was a good work out on my biceps, I could do it every day. I do recommend the 18" roller.
Also, I don't see how an 18" roller would give me more pronounced lines. It would seem, that I would get about half of the lines and that the roller would float a little better because it has more surface area.
What are holidays and IMO's? I'm not current with the lingo.
Also I know for a fact that it isn't the drywall or the framing.
Old 12-31-2007, 04:53 PM   #14
Old 12-31-2007, 04:54 PM   #15
I have since repainted it with a low-sheen and it turned out better. However, I still can see the lines at about a 10 degree angle. I don't know if this is normal cause I don't paint 150' walls all the time. Thanks for your guys input.
Old 12-31-2007, 10:17 PM   #16
jack75's Avatar
Trade: painting
I think the paint (ProMar 200 Satin) is fine, the Wooster frame is fine, the 1/2 inch nap is fine. The likely main cause here is ".. we even went so far as used all down strokes so the paint would stipple the same direction." The pronounced duller lines are perhaps resulted from rolling over the semi-drying paint unnecessarily, which in some way roughens the layer of sheen that's in the process of forming and drying naturally..
The additional step of going back and applying down strokes for uniformity purpose is not neccessary. After laying the paint on quickly and evenly, leave the section alone and let the paint do the rest. Hope this helps.
jack75 is offline
Old 01-01-2008, 09:55 AM   #17
...jammin
slickshift's Avatar
Holiday: missed a spot
IMO: In My Opinion
Signature Quote
One more airless power roller question steve-in-kville Painting & Finish Work 5 09-19-2008 11:09 PM
Titan power roller... My first impressions steve-in-kville Painting & Finish Work 0 06-17-2007 11:22 AM
18" Roller Attachment for Sprayer? all-pro Painting & Finish Work 3 06-01-2007 08:14 AM
old school roller, new to spraying remodeling joe Painting & Finish Work 18 03-01-2007 12:51 AM
old school roller, new to spraying remodeling joe Painting & Finish Work 19 02-25-2007 12:58 AM
