Old 10-10-2006, 06:36 PM   #1
Robie's Avatar
Trade: Cabinetmaker
Touchup question
Here are the facts:
New drywall
1 coat primer
2 coats SW Promar 200, flat, medium beige color
Rolled with 1/4" nap
I installed crowm molding today and got some smudges and such on the walls.
Is it best to just lightly feather these in with a brush or should I do something with a roller?
Probably sounds awfully basic, but I want to do it correctly for the best results.
Thanks.
"Don't tread on me"
Robie is online now   Reply With Quote
Old 10-10-2006, 06:39 PM   #2
My custom title
Brushslingers's Avatar
No.
Benn
Originally Posted by Brian
Brushslingers is offline   Reply With Quote
Old 10-10-2006, 06:46 PM   #3
My custom title
Well ok.. heh, you can prolly wipe most of them off with a damp cloth, touch up the rest with a brush.
Benn
Old 10-10-2006, 07:27 PM   #4
Trade: Painter
Pro mar 200 flat medium beige? You couldn't mess it up if you tried. Touch it up anyway you want. You won't be able to find the touch up after a day or two.
Joewho is offline   Reply With Quote
Old 10-10-2006, 08:19 PM   #5
Professional Painter
Richard's Avatar
Trade: Owner/Operator
It's true. You can wipe them then brush the areas. You said crown, so I'm assuming the 'smudges' are near the top of the wall anyway.
The flat paint saved you here....at least with the touch up portion of it. Then again, if you did use an eggshell or something washable like that, you would be able to wash the marks off without any need to touchup~something to consider...
Rich
Richard is offline   Reply With Quote
Old 10-10-2006, 08:26 PM   #6
Robie's Avatar
Trade: Cabinetmaker
Thanks. Just wanted to make sure.
"Don't tread on me"
Old 10-11-2006, 01:24 AM   #7
Terrence's Avatar
Trade: painting and carpentry
You're in good hands with allst--- uh, contractortalk.com
Terrence is offline   Reply With Quote
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 08:10 AM
Question about bidding vinyl wallcovering kanadaeh Painting & Finish Work 9 02-19-2009 05:29 PM
Basement Window Question gregt848 Windows, Siding and Doors 9 07-26-2006 05:29 PM
