#1 | |
...jammin
Trade: Rock Disciple
Touching Up Light Asphalt Shingles
I had to squirt a few wasps nests under some trim and got TAT (wasp spray) run-off onto some shingles
They are the light colored asphalt kind, and have stained kind of brown It looks just like when thinner is spilled on them Will a light wipe-down (top of the texture only) with some white/gray paint work to blend them back in? Thanks in advance for any tips, tricks, or solutions
Signature Quote Quote:
Remodeler
Re: Touching Up Light Asphalt Shingles
Slick i seem to remember someone asked about brown stains on shingles and i made a note oxalic acid worked to remove brown stain.
Damned if im gonna do it more than once. |
#3 | |
My custom title
Prolly would, I always used spray paint to cover up a mistake or two, never had runoff from wasp spray stain one though.
Benn Quote:
#4 | |
...jammin
Yeah I usually have a black spray bomb on hand for the occasional roof oops
These are light shingles though The "bumps" are almost-if not actually-white I'm assuming the bug spray lifted the black background gook those little white rocks are in, and stained them brown ...just a guess though Oxalic acid huh? I should just wipe the top of the "bumps" with it then?
Trade: Painting Contractor
Ya. Slick happened to me b4..... I just hit w/ spray also... but light colored????? good luck
Remodeler
slick i found the thread that was the acid answer and whoever used it said it worked its on DIY forum on roofing, thats where i saw the fix and noted it - ya know just useless info till ya need it.
By the way its not my idea its someone else's fix.
Damned if im gonna do it more than once. Last edited by lxdollarsxl; 08-09-2006 at 09:42 PM. |
#7 | |
My custom title
Please let us know if the acid actually works, or if you have to buy a new shingle.
Benn Quote:
#8 | |
...jammin
Ah...I popped over and found it-thanks
It was for rust stains, but perhaps it would work for me I'm not sure it won't remove the "white" If I can scrounge up some junk shingles, I may test it first If not, well...it looks pretty bad as it is, I may give it a go Thanks
Remodeler
good luck and i hope it works and save ya time.
unlicensed hack
Trade: wood butcher
Just a thought, How about bleach? Try a sample area where it won't be so noticable, just to make sure there won't be some irreversible reaction. But i would think a bleach/water mixture of 50/50 would take away the stain and leave the shingles looking original.
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread. |
#11 | ||
...jammin
Re: Touching Up Light Asphalt ShinglesQuote:
I would've slapped one in there ...I wish it were a shingle It's a barn type roof too so they face right out Oooph
#12 | ||
...jammin
It left the white rocks a little darker I didn't try try it on the stained area after that Though, I may do that 50/50 on a stained area to test it
| How many forum members to change a lightbulb? | Al Truistic | Off Topic (Non Trade) | 48 | 11-09-2008 01:46 AM |
| Owens corning a solid strip of tar | nolo | Roofing | 26 | 01-29-2008 01:25 AM |
| Reusing asphalt shingles | AbeBarker | Roofing | 8 | 04-19-2007 08:16 PM |
| Asphalt Shingles on Bow Window-Hip Caps?? | warrenc | Roofing | 7 | 08-15-2006 05:43 PM |
| metal vs. asphalt shingles | jlandry | Roofing | 2 | 12-18-2005 09:54 PM |
