Old 11-17-2008, 01:55 PM   #1
Trade: painting and refinishing
too cold to seal?
I gel stained a fiberglass door the other day and it was mid 50's. However, the weather has really turned and it is now low to mid 30's. I'm afraid the weather will not warm back up? I could take the door down but the sidelights will still not be done. Any advice? Will door be ok?
Traditions2 is offline   Reply With Quote
Old 11-17-2008, 06:34 PM   #2
Workaholic's Avatar
Trade: Painting Contractor
Can you tarp it off and run a heater before and after application? Or is this not practical for your situation?
Sean
Workaholic is offline   Reply With Quote
Old 11-17-2008, 06:52 PM   #3
A bit abrasive.
WisePainter's Avatar
If you have already dipped into the 30's you can write off the sealer. If you did burn a forced air heater, moisture would be a problem.
Hm.
Aha! Tarp off around the door and use 2 500w lights inside to heat the space.
Point the lights up of course.
Should be good to go.
My advice: Hire a real painter to do it.
WisePainter is offline   Reply With Quote
Chip Seal copusbuilder Concrete & Paving 8 12-15-2008 10:26 PM
cold weather framing inquisitator Construction 21 11-02-2008 01:59 PM
cold air return on slab construction LeroyJnks HVAC 4 07-11-2008 03:08 PM
FDA to declare cold medicines too risky for babies, toddlers eagleandbaby Off Topic (Non Trade) 0 01-17-2008 09:36 AM
No Cold Water streborn Plumbing 2 03-17-2004 06:06 AM
