Titan 880 Sprayer
Old 09-07-2008, 09:00 PM   #1
jltpainter's Avatar
Trade: Painter
Titan 880 Sprayer
I am thinking of buying another sprayer from a retired contractor, it is a Titan Epic 880 sprayer. From what i know of this sprayer he bought this 15 years ago used. He only used this to paint metal roofs.He was a roof contractor, So prolly only used it from time to time. I already have a small graco pump(395st)for smaller jobs but am in need of something a little bigger. This Titan pump is a highboy w/a 100 ft. of hose and a gun w/ a few tips(prolly worn out tips)My questions are :
1. What would be a good offer to make him for the pump(considering it pumps ok still ,which he says it does)
2. Can i still get parts for these if say the packings would go out,or anything else
3.Is this pump big enough to spray dry fall,or block fill, and would it handle 2 guns
4.And any other info anybody might know on these pumps
For some reason i can't find any info on these pumps, so any input is appreciated.Thanks in advance.
jltpainter is offline
Old 09-08-2008, 05:03 AM   #2
wink's Avatar
Trade: carpentry
Rewards Points: 150
Re: Titan 880 Sprayer
i had one given to me. i don't know if they can still get them but i got a rebuild kit from sherwin-williams. i don't use it much, but when i have it has worked great.you need to keep the oil to it and keep it clean, the guy that got mad at it and gave it to me asked if i would let him have it back, after i cleaned it all out. he liked it better than the one he got from homecheapo. good luck with it.
wink is offline
Old 09-13-2008, 08:09 PM   #3
jltpainter's Avatar
Trade: Painter
Update..... I bought this sparayer and it works great .It has two on and off switches.Thanks
Old 09-14-2008, 03:50 PM   #4
painterdude's Avatar
Trade: painting contractor(semi retired)
Rewards Points: 25
I had an 880, but it was back in the mid 1980's. Haven't seen or heard of one since. It was a great machine. I even hollowed out a tip and sprayed block filler on a fire wall. I'd be sure you can get parts and service for it. Try to find out how old it is. You could run 2 guns at the same time at least mind could. Let us know how this comes out. gl, p-dude
painterdude is offline
Old 09-16-2008, 05:32 AM   #5
jltpainter's Avatar
Trade: Painter
I think this one will run two guns also. I ended up getting this for $200. It has 100 ft. of hose and a 6ft. extension pole. The guy that owned it only used it to spray on that aluminum roof coating and always kept kerosene in it. I will update if i can find the parts. Thanks for the imput guys.
Tags
sprayer , sprayers , spraying , titan , titan sprayers
Brand New Titan 440i Leaking during setup???? WSTANDIS Painting & Finish Work 6 09-12-2008 02:53 PM
How to clean a clogged airless sprayer cmansmith Painting & Finish Work 9 09-09-2008 11:46 PM
5500 gas airless sprayer Cleveland NAV Contractor Swap 2 09-08-2008 06:36 AM
Spray King Sprayer for sale JCardoza Tools & Equipment 0 11-05-2007 05:54 PM
Titan 440ix jself52 Painting & Finish Work 4 02-16-2007 11:52 AM
