Titan 440i Problem
Old 02-04-2009, 06:47 PM   #1
logcabin man's Avatar
Trade: construction
Titan 440i Problem
Hi i wondered if anybody would happen to know why my spray gun looses pressure while spraying. I bought it second hand and it worked fine for 3 months or so, now when i use to spray internal varnish or anything else the pressure releases very slow and i loose the pressure and have to keep stopping. very annoying. I was going to put it in for repair but noticed a lot of people seen to know about these guns and thought it may be a simple problem i may be able to sort out.
Any advice would be appreciated.
Thanks
Aaron.
logcabin man is offline
Old 02-04-2009, 06:52 PM   #2
Workaholic's Avatar
Trade: Painting Contractor
Re: Titan 440i Problem
Sounds like your pressure contol switch on your machine is going bad.
Sean
Workaholic is offline
Old 02-04-2009, 08:11 PM   #3
Side Effects May Vary
ModernStyle's Avatar
Trade: Professional Painting
new packings ??
ModernStyle is offline
Old 02-04-2009, 09:21 PM   #4
capital city's Avatar
Trade: painting
Originally Posted by ModernStyle View Post
new packings ??
Thats what was wrond with mine when it kept losing pressure. Tried Builder Solution primer when it first came out. Guy said it sprayed great, come to find out it has so much crap in it , it ate up my packings on the first house. Thanks SW
capital city is offline
Old 02-04-2009, 10:31 PM   #5
Workaholic's Avatar
The packings could be the culprit. What is it doing when it is losing pressure? Is the piston going into over drive and running like the switch has been moved to prime?
My first thought though is still the pressure control switch.
Sean
Old 02-04-2009, 11:02 PM   #6
President of the world
world llc's Avatar
Trade: general contractor
first thing first... do you regularly lube your piston?
i can feel the jokes brewing....
world llc is offline
Old 02-04-2009, 11:05 PM   #7
czimcharopaints's Avatar
Trade: painter / trim / sheetrock / epoxy floors
the machine is easy to repair. that's why you should always strain your paint.
czimcharopaints is offline
Old 02-05-2009, 08:24 PM   #8
Paintpimp's Avatar
Trade: Paint
That product did that at first. The only solution was to use a ceramic ball in your sprayer and float water. The first five would work great, but it dried so fast that it would skin over and when the five got low, it would pit up the ball. When they purchased Duron they took their surfacer and slapped a SW label on it.
Back to the sprayer. When you lose pressure, look at the prime line, is it leaking anything. If it is, replace the prime spray valve. Ten minutes max to fix. If the prime line doesnt leak and the sprayer tries to build pressure but keeps kicking in, you either have a packing issue or the upper or lower ball need attention, usual a good cleaning.
Paintpimp is offline
Old 02-05-2009, 08:56 PM   #9
If you are switching between waterborne and alkyds alot the pick up tube and balls might be all gunked up. Normally I have found that if it is my prime valve that has went bad I can wiggle it and get the sprayer to pressure up for a second. I always use the strainers that tie to the pick up tube, they dont cost much and i like the extra protection.
Paslode Problem HomeWS Tools & Equipment 6 03-02-2009 10:32 PM
trane gas furnace problem funcky HVAC 7 01-28-2009 01:51 PM
Hot water problem PLUMBINGITALL Plumbing 7 01-24-2009 11:15 AM
Toilet problem Mike Finley Plumbing 5 11-06-2007 10:21 AM
