Titan 440i - Freeze-split Hose?
Old 03-16-2008, 10:15 AM   #1
artinall's Avatar
Went out to the storage facility where I keep my 440i and it found it standing in a pool of 50/50 oil-spirits solution kept in the line. Haven't powered it up to spot exactly where the leak is.
Do the pressure hoses spilt when temperatures drop low enough? Got down to mroe than -5 late winter around here.
Didn't suspect the solvent-based would expand, nor would the line. Guess it could be a seal but it seems doubtful.
artinall is offline
Old 03-16-2008, 01:05 PM   #2
Guru
paint_booger's Avatar
Trade: Union Paint & Drywall
Re: Titan 440i - Freeze-split Hose?
If you let it sit all winter ... you should do a little maintenance on it before using it. The solvent isn't the only thing that expands and contracts ... so do the rings. I'de check her over before bringing her to a job.
paint_booger is offline
Old 03-16-2008, 08:41 PM   #3
Paintpimp's Avatar
Trade: Paint
If you let your 440i freeze. And you see fluid around it. Here are a couple scenarios that will probably be true. Almost every 440i that I have worked that froze needs a transducer. You will know that it's it when you turn on your unit and nothing happens. Second problem you can incur when a sprayer freezes is that the fluid expands and can crack the cylinder that the piston is in. Either way you are looking over $125 to fix. Next winter keep it in a temperature controlled enviroment.
Paintpimp is offline
Old 03-16-2008, 10:20 PM   #4
artinall's Avatar
Paintpimp,
When it rains, it thunderstorms. Just what I need, in addition to work gone absolutely flat for months.
Are you saying the cylinder would crack before the paint line?
I've never heard of metal simply cracking with a drop in temperature.
Maybe if expansive water based paint were left in the line, or say water itself, but not spirits and oil.
Its not fluid around it, but rather the thinner/oil mix it was stored in, I think.
artinall is offline
Old 03-17-2008, 10:24 AM   #5
Paintpimp's Avatar
Trade: Paint
I have seen water left in sprayers crack a cylinder. Being that it was spirits and oil, less chance of it happening. You may be lucky and nothing is wrong as well.
Old 03-19-2008, 10:58 PM   #6
artinall's Avatar
Wondering how to check this out without potentially doing harm.
Flipping the switch -- if cylinder is cracked, can this scratch piston or...?
So far only felt underneath the housing and the oily substasnce is there.
(but house was wrapped near here too)
Seems like its the line mix but it could be the piston oil too, don't know.
artinall is offline
Advice for my Titan 440i kenrie Painting & Finish Work 23 05-10-2009 02:23 PM
Titan 440i Problems plazaman Painting & Finish Work 13 03-28-2009 03:33 PM
Titan 440i problems 863rikkip Painting & Finish Work 4 03-16-2008 09:17 PM
titan 440I shawpdx1 Painting & Finish Work Picture Post 3 09-18-2007 04:24 PM
The Titan 440i slickshift Painting & Finish Work 6 02-08-2006 08:22 PM
