Originally Posted by Richie-C
Hi all,
Bidding on a two-story colonial style house that will require me to stand on roof over the garage. The roof is sloped on both sides, and the exterior that I need to paint is too high to reach without a ladder. I do not paint many exteriors so I am kind of green when it comes to rigging up ladders, scaffold, etc.
What are some tips and tricks you use to not only place a ladder on the roof, but to stand on a roof while painting??
I recently painted the fascia trim on some doghouse dormers on a sloped roof, paint pot in one hand, brush in the other -- ohhh boy!
Richie
22 years painting ... don't have a clue to the size of roof but most painters have a lot of different size ladders . I painted a lot of roofs way before the boom generation. $$$$$$. It's easy, got a partner you trust.. use a chicken ladder, most painters ,at least older ones have several different sizes.
1.measure the roof. 2. break down the ladder 3.lay one side of the ladder on one side of the roof, the other part of the ladder on the other, make sure that you tie these two pieces together at the peak of the roof, using rope or rubber bungy cord. it's imperitive that you understand this.....
you are on on side your partner on the other side.
your partner is your counter balance. he can set on the ladder on the opposite side while you work on the other side. Do not try this without the other person on the opposite side. Or your ass will end up on the ground!
And always walk up a valley on a roof, to the peak then walk on the peak.
At least I think it's easier that way and safer. If no valley, then run like hell.
PAINTERS ARE ON A ROLL.............................................. .....................
