Trade: residential remodeling
Tip Sizes For Trim Spraying
how about some advice on spraying trim. i used a 214 and a 314, both fine finish graco tips with the green guards. i sprayed and moved at a good speed, but some places looked a little heavy but had no runs at all. not bad for a first time sprayer. been brushing and rolling for 22yrs and spraying is new to me. AND it's a GOD sent.!!!!!!! fast as sh-- thru a goose!!
#2 | |
My custom title
Re: Tip Sizes For Trim Spraying
Go down a little on the orfice... I use a 211 on trim and at times a 312 for trim and doors, really depends on how much i'm spraying... I have a low psi low gpm sprayer I use for oil and finer finishes. As you get better you will be able to leave your sprayer on high and blow out anything without much worry. Now when you start wanting furniture grade on shelves and such look into cup guns.. not gravity feed guns.
Benn Quote:
Professional Painter
Trade: Owner/Operator
I use a 211 with my airless...it's a fine finish tip that makes you feel like your using an hvlp...I wouldn't use anything else, especially if doing a lot of installed cabinets or bookshelves.
Educated Applicator
211 here too.....makes a nice finish, and a 411 for doors.
Had a 209 once, was way too small. |
Trade: Painting Contractor
As i said before i use 211 for trim and a 311 for the doors.
Sean |
how about a 210 fine finish graco tip with the green guard???? reason is that's all they have in sw. i'm in fort walton beach, fl and new to the area. been here a 1yr. i used a 214 and today it seems to shoot a bit too much paint. i had my first run and a metal door and thank GOD i check up on my work and caught while still wet. so how about the 210, too small or seek and find the 211????
Tampa Painters |
all hail the 211 tip!!!!!!!! thanks so much guys for the advice. man.......those sw morons are just that;morons. i found the 211 at color wheel paint store and it worked great!!
thanks again.!! |
Trade: Painter
The Graco fine finish tips come in even tip sizes (10, 12, etc) The regular tips are odd sizes for the openings. So any Graco 11 is not a double orifice fine finish tip but a regular spray tip, to my knowledge anyway.
Educated Applicator
Re: Tip Sizes For Trim Spraying |
211 tip, strain the paint to remove all snots and then buy a pair of pantyhose to cover the rock catcher- works great. You will never have to flip the tip all day long
hey dean,, you're right about the odd and even numbers of tips. i am just so gratefull of all you guys. i've received more honest advice here than any paint store ever. thanks again guys, ya'll are the best.
World Champion
What Kind of paint are you blowing through those tips?
i'm blowing promar 2oo semi-gloss thru a 211 tip. works great.!!
World Champion
So your spraying latex through a size 211 tip?
i didn't really know that could be done. How? What spray rig are you using? i have a titan 440i will it work? |
Trade: painting
Should spray through that. I have a smaller spray tech and it goes through fine. In fact i've sprayed pro classic through it, which is a pretty heavy bodied paint.
Yes it will without a doubt work for that.
Sean |
#18 |
i have a 190es from hd. and it works great; though i don't have any other experience with other higher end sprayers. any advice versus the 190es???
#19 | |
Re: Tip Sizes For Trim SprayingQuote:
Sean |
#20 | |
Pro Painter
Interesting. I could see a 212 double orifice tip for latex, but a regular 211? Does it come out spitting? Does it even atomize properly? Using a 211 for latex goes against pretty much everything I've ever learned. .011, .013 sizes are usually for thin stuff like stains, .015 .017 are for latexes, and .017 or .019 are for things like lacquer and epoxies.
| Spraying pressure, tips and mostly technique | bgpainter | Painting & Finish Work | 11 | 08-12-2008 11:39 PM |
| spraying has ruined my brush and roll estimating | Traditions | Painting & Finish Work | 11 | 09-15-2006 04:31 PM |
| hvlp vs. airless for spraying trim | Traditions | Painting & Finish Work | 13 | 08-25-2006 08:49 AM |
| spraying on stilts!!!!! | drywall | Drywall | 5 | 07-06-2006 11:51 PM |
| Spraying Outside Corners with Spray Shield | remodelnut | Painting & Finish Work | 3 | 02-01-2006 07:30 PM |
