Trade: Custom Home Remodeling 30+ yrs
Tip For Cleaning A Used AIRLESS HOSE
I've used this method for restoring brake lines on old motorcycles and it works for Airless lines too.
First I'll run warm soapy water through the line using the airless then remove the hose with some of the solution still inside. (1 Cup of Krud Kutter to 1 Gal. Hot Water) I'll take weedeater line (Preferably square or one that has rough sides) and run about 51 feet through my 50' hose and then attach the line to my cordless drill. Being that the line is soft plastic it won't marr the inside of the hose. With brake lines they are usually only a max of 5 ft long so I make a point on the line and drill as I shove it through cutting through all the gunk... It doesn't seem to work when it's 51' long. You can lay the hose full length or put a couple of loops in it to add resistance and make the line really get those sides clean. MZ-HANDYMAN |
Tech Geek
Trade: Property Management/Facilities Manager
Re: Tip For Cleaning A Used AIRLESS HOSE
I've never tried it, I would just buy a new hose. I like your idea but it might work better at the 50' mark if you tie a fishing swivel on the end to put some tension on it.
#3 | |
Re: Tip For Cleaning A Used AIRLESS HOSEQuote:
The swivel may work well after running the weedeater line through but may tend to grab the hose from the inside making it spin too?! MZ-HANDYMAN |
vandy
Trade: painting, decorating, wallcovering
i would just run laquer thinner through it for 30 minutes, then I would run hot water through it for another 30 minutes. if that didn't do the trick, I would spend the money on a new hose.
Trade: Painting Contractor
Well I was not going to say anything because I did not want to be the blame if another one of your threads tank.
My professional opinion is on the next job bill a new hose into the job. Then you will have a new hose. If you have never had a hose blow apart on you then you just won't understand why it is 50 bucks well spent.
Sean |
| The Following 3 Users Say Thank You to Workaholic For This Useful Post: |
Custom Stuff
Trade: General Contractor - Custom Renovations
__________________________________________________ ___________ I EXPECT THAT SOMEDAY I WILL SEE THE FRUITS OF MY LABOR. IS IT SOMEDAY YET? ![]() Clifton, Great Falls, McLean, Fairfax Station, Manassas, Virginia Renovation Contractor |
| The Following User Says Thank You to Mike(VA) For This Useful Post: | JumboJack (07-27-2009) |
Store Owner
Trade: Paint Store Owner
BUY A NEW HOSE PLEASE!!!! Airless hoses should be replaced yearly!!! Has anyone here seen an injection wound? Lemme tell you, its pretty frikin nasty, and the only fix for it is amputation. 2 days ago one of my customers was moving a ladder to clear his spray line...he grabbed the spray line and pulled it into the next room and BANG!!!....Pin hole leak in the line and injected into his left index finger. Went to the hospital, and they butterflied his finger open, cleaned the wound, stitched him up and sent him home to wait....next day he went for amputation.
Please please please, change your lines and use tip guards ( no ghetto cut up guards and safeties) Unless a body part is worth less than $50 |
| The Following User Says Thank You to NCPaint1 For This Useful Post: | MZ-HANDYMAN (08-07-2009) |
#8 | |
Did he hit your insurance for the bills and of course the damage to his home?
Sean |
#9 | |
Store Owner
It was meant as an example of what can happen, an example that i've personally seen. But it's your body, and if spending $50 to save possible limb loss isnt worth it to you......to each his own I guess
www.northcromwellpaint.com Benjamin Moore Paint, PPG Paint, TWP Stains, Sikkens Wood Finishes, Airless Sales, Service, and Rental |
#10 | |
I agree 50 bucks saves a lot of heart ache.
Sean |
#11 | |
Trade: Painting & Flooring
"Yeah... It's worthy of a sig quote." |
Store Owner
This one just lost a finger, but it all depends on where you get injected, and how long before its treated, and what you are injected with. Think about it, you have just injected an array of chemicals into your body that is being absorbed into your bloodstream. Its an instant infection, and if un-treated they can turn fatal.
I gotta admit I got injected in my index finger about 30 years ago I think the sprayer was called a bumblebee or something like that but it shot a pinhole right across the tip of my finger. Luckily it was only water. It was our first sprayer and I was cleaning the tip Back then they (Tips) looked like this.
Not much of a guard back then. It felt like someone shoved a needle through my finger sideways. IT WAS A SUPER BEE!!! (I think!?) Last edited by MZ-HANDYMAN; 08-07-2009 at 12:20 AM. |
Side Effects May Vary
Trade: Professional Painting
Flat tips suck IMO
#15 | |
Trade: paint contractor since 1974
Jim |
Trade: Painting - Restoration
when i was a kid, i once fabricated a cheap fish tank pump to circulate thinner in a line... Sad thing is, i cant remember if it worked or not.
#17 | |
Store Owner
That would be a BINKS SuperBee....Friggin awesome pumps, the company has been outa business for more than 20years ( not for sure...but its been a looooooong time ) IMO, some of the best pumps ever made!!! Just fixed one the other day, some parts are hard to come by, but you can still get them.( have to be ordered from the UK and takes forever to get them ) Off topic but...The lead engineer from BINKS went to work for a company called AIRLESSCO some years ago....If you look at the Binks piston pumps, they are very similar in design to the Airlessco's....hmmmmmm
| Tags |
airless hose, cleaning, mz-handyman, tips, tricks ![]() |
| 1/8" id Airless Hose | Al Truistic | Painting & Finish Work | 6 | 08-12-2010 04:18 PM |
| paint is stippling out of airless spray gun | scottcoleman | General Discussion | 2 | 01-16-2009 05:59 PM |
| Blasting hose questions? | edjohnson | Sandblasting | 17 | 12-27-2008 07:40 PM |
| Hose Reels | killzoneq2 | Sandblasting | 4 | 05-07-2008 08:52 AM |
| Graco / Magnum XR7 Airless Paint Sprayer $285 | ATLT | Contractor Swap | 0 | 11-27-2007 10:03 AM |
