Tinted Poly
Old 12-11-2006, 09:02 PM   #1
Alkyd's Avatar
Trade: painter
Tinted Poly
I stain a front door and the homeowner said it was to light. I reapplied a second coat of stain the following day and homeowner said it was still to light. The next day I tinted some poly and now the homeowner says it is to dark. How can I strip off the poly without damaging the stain. Can I rub lacquer thinner or xylene over the tinted poly to make it lighter? Thanks guys
Alkyd is offline
Old 12-11-2006, 09:12 PM   #2
...jammin
slickshift's Avatar
Trade: Rock Disciple
Re: Tinted Poly
I think you are hosed
But just in case someone has a better answer, was kind of poly was it?
Signature Quote
slickshift is offline
Old 12-12-2006, 11:13 AM   #3
metomeya's Avatar
Re: Tinted Poly
Tough one,
I would think a chemical remover would be your best bet, a lot of them advertise that they take out stains, but from all the complaints I've heard working at a hardware store they never do.
They are messy, you could try sanding but you will probably end up eating into the wood in some places, but if you still have the stain you could stain those areas.
metomeya is offline
Old 12-12-2006, 04:59 PM   #4
JNLP's Avatar
Trade: Painter
Re: Tinted Poly
You could strip it off with Bix, but would need to stain it again.
JNLP is offline
Old 12-12-2006, 09:17 PM   #5
Alkyd's Avatar
Trade: painter
Re: Tinted Poly
I used helmsman spar poly. Someone told me Formby had a product for this for refinishing purposed. Does anyone know what it might be?
Alkyd is offline
Old 12-12-2006, 10:00 PM   #6
BMAN's Avatar
Trade: Painting & Remodeling
Re: Tinted Poly
Try denatured alcohol and steel wool, rub it in lightly and it will remove a light amount of the top coat and some of the stain.
BMAN is offline
Whats a good poly for tables rservices Specialty Coatings 6 06-10-2007 05:25 PM
Flat Poly to a satin poly lornmastro Painting & Finish Work 10 04-22-2007 07:00 PM
poly urethene donb1959 Painting & Finish Work 3 01-29-2007 11:37 PM
Oil base or water base poly? jhf469 Flooring 4 11-24-2006 11:36 PM
How many coats with tinted primers? Mike Finley Painting & Finish Work 8 05-25-2006 08:45 AM
