Tin/metal Roof
Old 02-17-2008, 09:23 PM   #1
boman47k's Avatar
Tin/metal Roof
I try to stay mostly in interior painting, but might have a lead on a shallow pitched tin roof. I have done or helped do a couple of tin/metal roofs when working for someone else. Both of these were done with electomeric topping. One was because it needed painting, the other because it leaked. There was no prep done so I do not know how successful leak stoppage was as I didn't work much for that person. What I need to know is what is the best procedure for painting a tin roof? Actually, I need tips on materials to use. I should add this in nw alabama.
boman47k is offline
Old 02-17-2008, 10:07 PM   #2
plazaman's Avatar
Re: Tin/metal Roof
prep should be pressure wash, spot prime rusted areas, and top coat. Its the top coat you would need help with.
plazaman is offline
Old 02-17-2008, 10:53 PM   #3
boman47k's Avatar
Re: Tin/metal Roof
I got the wash, prime and top coat part, but not sure about materials to use. I did a search and seen red oxide primer suggested. Someone else suggested oil primer. So I guess what I need to know is what to wash it with, prime it with, and what is the best top coat for tin roof.
I was thinking oil would be the wrong primer for galvanized metal.
boman47k is offline
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
Need help designing Roof for addition jaymay75 Framing 21 06-17-2006 10:47 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
