Taking Off And/or Painting Exterior Oil Paint On Wood Siding
Old 07-28-2006, 07:45 PM   #1
Professional Painter
Richard's Avatar
Trade: Owner/Operator
I have a job where I need to either repaint (1 coat over the old) the siding or remove the paint(because of cracking and peeling) down to bare wood. The paint used on the house prior to me was Pittsburgh. I am staying with pb (only by customers request) but when the wood is bare I'm going to use a SW oil primer because I've had good luck with all there primers, and then topcoat with 2 coats of the pb.... Now, my question- What is the best way to remove the paint down to bare wood. I dont want to burn. Im good with a 5" disc sander(no swirls or dings), but maybe there is an easier way. Keep in mind...I'm doing the work from my extension ladders, due to the fact that I havent invested yet in staging. Also, what are your standards on recoating (simple 1 coat refresher) over oil? Thanks..sorry so long
PS- I dont bite
Richard is offline
Old 07-28-2006, 09:49 PM   #2
Jon F's Avatar
Trade: Log Home Services
Re: Taking Off And/or Painting Exterior Oil Paint On Wood Siding
...I think the best remover there is is Removall310 made by Napier Environmental. Used this week, removed about 10 coats of shellac in one pass. Removes paint easily, and they have other formulas that may be more to your use (doubt it).
1) VERY expensive, both product and process
2) You'll have a mess (removed paint)
This would be a very expensive job if bid this way. Customer better be pretty darn quality-conscious to choose this over just a re-coat.....gonna be tough selling on your part. But if you get it, this process will get your paint off down to cedar.
Jon F is offline
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 21 03-30-2010 08:02 PM
paint stained wood jmthouston Painting & Finish Work 14 03-05-2007 05:19 PM
Paint needham Painting & Finish Work 2 03-02-2007 07:17 AM
Roof paint Teetorbilt Roofing 3 05-07-2004 05:47 PM
