SW Primer/surfacer?
Old 03-10-2007, 07:46 PM   #1
BobbyD's Avatar
SW Primer/surfacer?
Has anyone used SW Builders Solution primer/surfacer? Just wondering how it compares to normal PVA primer. Does it really help drywall imperfections and taping seams?
Thanks
BobbyD is offline
Old 03-10-2007, 08:34 PM   #2
My custom title
Brushslingers's Avatar
Re: SW Primer/surfacer?
Builders Solution is the bottom of the line... nuff said.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 03-10-2007, 09:27 PM   #3
ALLIN1's Avatar
Trade: Home Improvements
Builders solution is high in silica and is high build it works great for building up the surface to cover minor imperfections and joint banding. Not a great sealer, sucks up your first coat of paint. Very compareable to USG's first coat primer surfacer.
I like it and for the price 7.00 a gallon not a bad product at all
ALLIN1 is offline
Old 03-11-2007, 12:13 PM   #4
Dorman Painting's Avatar
Trade: Painting Contractor
Thanks
If you've got a so-so drywall job in front of you, you're best bet is to use this stuff. I've used it on renovations when I have to strip layers of wall paper and skim coat the walls. The high build primer makes me worry alot less about my skim coat. For the price I pay it's a great product. VERY thick and does it's job IMO.
Dorman Painting is offline
Old 03-11-2007, 01:38 PM   #5
Pro Painter
AAPaint's Avatar
I've used this product on new construction before. Although a very cheap product, it does do what it says and give a very high build film that hides a lot of crap in the drywall, hence the reason the new const. guys are using it. Cheap and hides their drywall guys mistakes.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 03-12-2007, 09:42 PM   #6
Professional Painter
Richard's Avatar
Trade: Owner/Operator
I've used it. It's thick, but it works wonders. So it's cheap, big deal...it works fine and really does hide imperfections. Plan on lower sq. ft coverage per gallon.
Richard is offline
Old 03-12-2007, 10:30 PM   #7
Joewho's Avatar
Trade: Painter
So, I should go to SW and just ask for the BS?
Joewho is offline
Old 03-13-2007, 01:18 AM   #8
Woz the Painter's Avatar
They will give it to ya...
Woz the Painter is offline
Old 03-13-2007, 08:54 AM   #9
Pro Painter
AAPaint's Avatar
Yes, it's cheap crap...but it does do what it says. Will you see it spec'd on any of my jobs? NO.
-AAPaint
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 03-13-2007, 01:01 PM   #10
Joewho's Avatar
Trade: Painter
Every product has it's place. Just couldn't resist a little joking around.
I wonder how it would do with satin or semi on top.
Joewho is offline
Old 03-13-2007, 02:07 PM   #11
My custom title
Pretty decent Joe... actually only thing I use it for is cheap primer when I need high build.. like covering wallpaper.
Benn
Old 03-13-2007, 05:14 PM   #12
Workaholic's Avatar
Sean
Workaholic is offline
