SW Oil Base Enamel Not Drying
Old 12-31-2008, 01:17 PM   #1
72chevy4x4's Avatar
I painted a set of french doors last night using interior SW alkyd enamel (think its its the Classic Pro XP). After 18 hrs, the paint still is not dry...upper 60's with 30-35% humidity. The paint had been sitting on the shelf for 6 months, but I mixed it well.
Any idea what's going on? The coat is still wet!
72chevy4x4 is offline
Old 12-31-2008, 01:28 PM   #2
Wolfgang's Avatar
Trade: Painting & Remodeling
Re: SW Oil Base Enamel Not Drying
Try moving some warm air around them. Set up a space heater w/fan or a space heater and set a fan behind it on low. Every once in a while I run into the same problem and its worked for me. If it doesnt work, you've got a real chore ahead of you. Good Luck.
Wolfgang is offline
Old 12-31-2008, 02:14 PM   #3
Tom Struble's Avatar
Trade: siding
i agree some warm air flown around them should work ive also had this problem with sw A100.
whatever you dont dont top coat till it is dry thoroughly, learned that the hard way
Tom Struble is online now
Old 12-31-2008, 02:51 PM   #4
hoya's Avatar
Trade: Painting Contractor
dido try a fan if you don't have a space heater......
hoya is offline
Old 12-31-2008, 03:13 PM   #5
Thom
thom's Avatar
I'd skip the fan if the paint is still tacky. The fan will add more dust to the finish. The space heater will work fine but don't burn it. You really don't want the paint temperature to exceed 120 degrees or so.
thom is online now
Old 12-31-2008, 06:31 PM   #6
A bit abrasive.
WisePainter's Avatar
Are you are using a dark color, or Semi~Gloss?
It sounds like the paint is still curing, and 24 hours is not an unreasonable amount of time for enamel to fully cure if the room is not 75 degrees.
My advice: Hire a real painter to do it.
WisePainter is offline
Old 12-31-2008, 10:52 PM   #7
72chevy4x4's Avatar
it's a semi-gloss. turned a spaced heater toward the doors to increase the heat, but ambient room temp is probably around 65 degrees. The immediate area where the small heater is blowing is finally tacky whereas the rest of the door is oily-that's after 28hrs.
Should the temp be at a minimum in the 70's when using oil based paints? Think I've learned a lesson.
Old 12-31-2008, 11:21 PM   #8
A bit abrasive.
You need a longer curing time for an alkyd semi gloss sheen.
If you brushed or rolled the paint on instead of spraying add more time for the paint to properly cure.
The higher the sheen the warmer it needs to be in the room so the mid 70's is what you need.
Old 01-01-2009, 08:31 AM   #9
Frankawitz's Avatar
When I started out we only used oil base paints, for everything. the rule for oil paint was minum dry time 18 hours to 24 hours before you could touch any door or casing, or they would be ruined. and you have to sand them down and redo, then it took another 18 to 36 days for the paint to completely cure depending on the season when you painted them. Oil takes longer to dry that's why it holds up better then most Latex paints. But as time goes on the Government(EPA) will have away with all oils before to long.
www.frankawitz.net
Frankawitz is offline
Old 01-01-2009, 08:13 PM   #10
Dmax Consulting
Dmax Consulting's Avatar
Trade: Paint Contractor
I've had problems with ProClassic XP Alkyd before. Here's the deal with it. Proclassic XP is one of the only low VOC alkyd coatings on the market. The low-VOC resin package takes a lot longer to cure.
Here are some things that you need to remember with using this product:
Use Thin Coats (per manufacturer specs) - this speeds the cure/recoat time
Dark colors are even slower to dry - because of the ethlylene glycol colorants that SW uses, the more color the longer the drytime.
Dmax Consulting is offline
Old 01-01-2009, 10:04 PM   #11
Painting Contractor
Damon T's Avatar
apply thin coats, and if possible use Naptha to thin. This will evaporate quicker than mineral spirits. May not be available in your area?
Damon T is offline
Old 01-07-2009, 01:51 PM   #12
Dorman Painting's Avatar
Put some Japan drier in your oil and watch it dry, can't believe nobody has mentioned Japan drier.
Dorman Painting is offline
Old 01-07-2009, 01:56 PM   #13
Trade: siding
i used japan dryer in A100 oil and it worked great
Old 01-07-2009, 05:21 PM   #14
A bit abrasive.
That's because nobody uses that stuff anymore, when I say "nobody" I mean anyone under the age of 60.
I use Naptha for drying alkyd based materials in a hurry.
In this case it turns out that it was a case of operator error.
Old 01-07-2009, 06:28 PM   #15
President of the world
world llc's Avatar
Trade: general contractor
i think nobody mentioned japan dry cause the paint is already on the door
i like naptha alot, but only when spraying... i use turpentine when brushing/rolling to keep it workable longer. my old boss used to use the japan dry, but i hear bad stuff about it like sometimes it will dry too fast and caust the paint to prematurely fail...
world llc is offline
Old 01-07-2009, 07:03 PM   #16
A bit abrasive.
another solvent used by those over 60...
Last edited by WisePainter; 01-07-2009 at 07:04 PM. Reason: Sorry about that low blow world llc, I worked with lacquer today and I am a bit punchy at the moment.
Old 01-07-2009, 09:38 PM   #17
world llc's Avatar
i had to get my glasses to read that tiny font
Old 01-07-2009, 09:41 PM   #18
Give me a break, I'm 33 and have used it for years because it works. This guy wouldn't be having these problems if he had used Japan drier.
Old 01-07-2009, 10:05 PM   #19
Workaholic's Avatar
LOL i am 35 soon to be 36 and i like japan drier for oil. I also like naptha. Never have actually used any turpentine for an additive. That is old school right there.
Sean
Workaholic is offline
Old 01-07-2009, 11:09 PM   #20
world llc's Avatar
i'm 28 and i was taught at 18 to use turps
turpentine evaporates slow
mineral spirits evaporate about the same rate as what's in the oil
naptha evaporates quickly
i like turps cause i can have an open pot for a few hours and not have to clean my brush so often...
base trim on island KentWhitten Finish Carpentry 33 01-16-2009 10:19 AM
Old Floors - Water Base Sealer is down - Grain Raise JPlous Flooring 15 12-22-2008 10:00 PM
New base housing Higgs General Discussion 5 11-10-2008 06:18 PM
Latex over Oil base paint is peeling iceman61 Painting & Finish Work 19 10-16-2008 12:44 AM
vendors for oil base. mdshunk Painting & Finish Work 5 11-11-2006 08:34 PM
