SW Insulating Paint
Old 01-31-2009, 06:49 PM   #1
sparehair's Avatar
Trade: Painting, flooring
SW Insulating Paint
Has anyone had the pleasure of applying the sw aluminum insulating paint for attics? It's kinda metallic looking.
B
sparehair is offline
Old 01-31-2009, 09:23 PM   #2
President of the world
world llc's Avatar
Trade: general contractor
Re: SW Insulating Paint
B
the E-barrier? seen pdoduct desctipt, never used it...
world llc is offline
Old 02-01-2009, 04:42 AM   #3
A bit abrasive.
WisePainter's Avatar
Last time I used an e rated paint it sucked. But it was cool when we washed out the bucket to see a solid mass of metal sludge left over in the bottom.
My advice: Hire a real painter to do it.
WisePainter is offline
Old 02-01-2009, 07:19 AM   #4
Frankawitz's Avatar
Must not have boxed that paint to good huh?
www.frankawitz.net
Frankawitz is offline
Old 02-01-2009, 12:48 PM   #5
A bit abrasive.
www.frankawitz.net
lol, we used a large amount of it and I tried everything to keep the metal where it was supposed to be. But alas gravity had its way with it every time.
It was cool stuff but this was 9 years ago and even then I didn't see it taking over the market.
Old 02-01-2009, 01:45 PM   #6
Smart phone? Scan me!
nEighter's Avatar
Trade: Painting/Framing/Drywall
I have used it and like it. I have it on my own house. Is there anything you wanted to know about it? I took pics of the whole process too. The hardest part of the whole job was to navigate around the attic and move the insulation around to do the job.
nEighter is offline
Old 02-01-2009, 02:37 PM   #7
nEighter's Avatar
Thought I would throw up some pics for you. When you apply it you need to cover the rafters also. You are just spraying up a big envelope that is your roof decking. Stuff cleans up easy, smells... I couldn't put my finger on the smell of it.. not bad though. I am hitting this stuff hard on all my paints I do. I give out E-Barrier literature in every estimate/bid I give out. When this stuff finally catches on.. I plan on doing ALOT of it
nEighter is offline
The Following User Says Thank You to nEighter For This Useful Post:
sparehair (02-01-2009)
Old 02-01-2009, 03:47 PM   #8
Bender's Avatar
Trade: Painting Contractor
I haven't used it but I think its a scam. Whats the R-value? Like .3 or something?
Bender is offline
Old 02-01-2009, 04:02 PM   #9
nEighter's Avatar
It traps radiant heat.. not an R value, it traps the radiant heat in and blocks the UV from entering into your attic. It has a perm rating of .32 ( the lower you get from 1 the better) so basically it blocks 68% of the radiant heat from entering and escaping.
radiant heat
  –noun Thermodynamics. heat energy transmitted by electromagnetic waves in contrast to heat transmitted by conduction or convection.
it isn't as simple as insulation..
nEighter is offline
Old 02-01-2009, 04:31 PM   #10
Bender's Avatar
Don't try trickin' me with them big fancy words Nate
Bender is offline
Old 02-01-2009, 04:46 PM   #11
nEighter's Avatar
It didn't work.. drat!!
nEighter is offline
Old 02-01-2009, 10:46 PM   #12
sparehair's Avatar
Perm has nothing to do with heat. It's the ability of water to pass the paint barrier. The higher the perm the greater the ability of water to pass. It is not a ratio either; it's a scale. That's all I could get out of my SW rep anyway. SF-1 Stain blocker has a perm rating of 1. Water should not be able to pass through it ("It's like 6 mil plastic," says the rep).
The pics of the ebarrier were awesome. Thank you
Old 02-02-2009, 01:16 AM   #13
nEighter's Avatar
awe you know what I meant emissivity or emittance (which is the E in E Barrier).. I got my terminology wrong was thinking Vapor Barrier there for a second.
here is a good article to read:
http://www.enn.com/green_building/article/32849
nEighter is offline
Old 02-02-2009, 08:41 AM   #14
Traditions2's Avatar
Trade: painting and refinishing
looks like silverbrite. I've tried to sell ebarrier to some people on new home construction without much success.
Traditions2 is offline
Old 02-03-2009, 11:38 AM   #15
Youngster
Cache's Avatar
Trade: Builder / Consultant / Designer
If the above article is correct, then the appropriate time for a radiant barrier for new construction would be during the framing phase. Most builders have seen radiant sheathing products for roofing that have the foil laminated onto the sheathing. According to the article, those types of barriers are far superior to the paints. Seems that it would be hard to convince a builder or HO who passed on the better product to change his mind and decide at the end of the build to use the inferior product. That might be why it is a tough sell. You might try focussing your attention on the existing homes market for products like this. Assuming that they actually do work well enough to justify the cost.
Cache is offline
Old 02-03-2009, 11:40 AM   #16
good point
Old 02-03-2009, 11:46 AM   #17
Tom Struble's Avatar
Trade: siding
so what exactly is it doing when you paint it on the bottom of your sheathing? reflecting attic heat back down towards the floor?I thought radient barriers only worked with an air space so it wouldnt be doing anything to lowering your attic temps?
Tom Struble is offline
Old 02-03-2009, 07:37 PM   #18
Youngster
Cache's Avatar
I think the argument is mainly that it acts as a barrier against infrared radiation. Shiny metal roofing will do a lot toward reflecting heat away from the attic but I don't think that anyone is claiming that these paints will work in that way. Rather, they prevent infrared radiation from penetrating and creating an oven in the attic.
AFAIK, the air space that you are referring to has more to do with the resulting conduction that results from the radiation. IOW, infrared radiation hits shiny barrier and is no longer able to penetrate, but while the barrier stops radioactive penetration if the surface heats up, heat is still conducted through to whatever substrate the barrier is coupled to. So they specify an air gap that acts as a conduction barrier.
Cache is offline
Old 02-03-2009, 09:56 PM   #19
Trade: siding
Old 02-04-2009, 12:59 AM   #20
remodeling joe's Avatar
Trade: residential remodeling
OMG!!!!!!!! will the damn thing work or not to keep the hot air from enter into the attic.???? if yes, then how much versus just having insulation between the joist????
remodeling joe is offline
Aura Paint Review (Matte Finish) DeanV Painting & Finish Work 43 05-06-2010 09:45 PM
Paint Sprayers BiggersJunior Painting & Finish Work 27 01-12-2009 09:49 PM
Green Paint Division toddcla2002 Painting & Finish Work 17 01-24-2008 03:22 AM
