Trade: painter, roofer
SW Industrial, Marine Coatings
I wanna use the "DTM 100% Acrylic water based industrial marie coating" (think its a high gloss) on some pre painted (SW pro mar eggshell) wood trim. Trim is new. And Ive used the DTM on metal many times never on wood. My thoughts are since its acrylic im good to go on wood. Unfortunatlay cant read the can cuz I normally use the specification side as my pour side (might rethink that). Neways would be nice to have confident answer for 2maro morning if anyone can help.
Trade: Painting Contractor
Re: SW Industrial, Marine Coatings
You could paint tomato soup on it too but that doesnt make it right. Go spend 20 bucks on the right product.
Well first of all its a great product, if its the right substrate which is my ? Plus I need the color to match metal rafter beams that I painted on the ceiling. Which I have a gallon left over. So you see it would make sense.
I would think it would be fine as a top coat. Call your local SW to double check.
vandy
Trade: painting, decorating, wallcovering
DTM Acrylic is great.
Just because it can be applied Directly To Metal does not mean that it can only be put on metal. i've used it on metal, masonry, and wood doors (properly primed though) and it was fine. i guess it could be called Direct To Most any substrate |
DTM is good on wood. My guy just painted my basement risers with it last week. Good stuff. I use it all the time for metal doors, etc..
Ya the trim came out great. The finish is superb, really easy coverage in 1 coat. I beleive the color was Crayon Clay or something. It matches old brick walls great.
Project Manager
Trade: Industrial Painter
www2.sherwin-williams.com/im/default.asp?thequerystring=nothing&search=keyword& endthequerystring=nothing&search=keyword&formEleme ntName=&returnField=&view_page=0&price=false&doMsd s=&keywords=dtm acrylic&image1.x=4&image1.y=9&image1=Find#quicksea rch
I use this regularly. A little bit of a pain but the answers are usually much better than the answer from the store.
Mike Industrial Painting Contractors - Commercial Painting Contractors - Industrial Painters - Industrial Painting Projects |
A bit abrasive.
Never used it for anything other than metal doors. In Florida I had to paint 2 large metal safety doors on a Target, it was on the east side, and waiting for the sun to move was not an option...in Florida.
So I rolled as fast as I could but the doors were a cool 120 degrees by 7 a.m...in Florida. It was a hard fought battle but I was able to lay it on heavy and quickly manipulate it with a white foamy roller so there were few lap lines or boogers. It was a draw actually. What are the benefits of using it on wood?
My advice: Hire a real painter to do it. |
You should be fine, that is a great product.
#11 | |
Re: SW Industrial, Marine CoatingsQuote:
#12 | |
A bit abrasive.
It is something I never would have thought of unless I was in your situation, but I can appreciate the durability it would offer. I'm still not sure if I would consider using it as the primary topcoat for wood trim. For what it's worth I have been keeping my eye on the All Surface Enamel for the past few years and it performs well on wood.
My advice: Hire a real painter to do it. Last edited by WisePainter; 01-23-2009 at 11:30 PM. Reason: TGIF!!! |
Trade: Painting & Remodeling
Never had a problem with DTM, though it can be tough to apply on hot surfaces. I used to paint printing presses years ago when I first started my business, it was all brush and 3" foam rollers. Made hellaciously good money, but the traveling sucked.
Trade: general
FYI- I deal with a small SW outlet store in SW Michigan, I always ask them to research my questions through their network, they have many REAL experts in different fields. They have a commercial coatings rep that has provided me with some excellent information through the years.
I don't want to knock the store managers but I've noticed a lot of turnover through the years and am not comfortable them. |
#15 | |
A bit abrasive.
It is a dark and dirty place to make your way to the top. My Boss was fired after 17 years because he was tired of the B.S. and began skimming products and money. Ended up behind the Home Depot paint counter as a Manager...then he realized he screwed up. Dark, and dirty. A company that has been successful for over 135 years knows how to keep things in their favor. They were around before FORD and apparently will be around long after.
| Industrial Chiller Plant operator Stummped by Rheem | zoli | HVAC | 5 | 01-16-2009 12:34 PM |
| Flakeline coatings | John Watts | Sandblasting | 0 | 01-10-2009 08:09 PM |
| Marine, republican, media | Burby | Off Topic (Non Trade) | 1 | 12-13-2008 10:54 AM |
| Impact & Chemical Resistant floor coatings | NAV | Specialty Coatings | 4 | 09-12-2008 03:29 PM |
| Multispec coatings | JELLYBEAN66 | Specialty Coatings | 1 | 09-05-2008 11:35 AM |
