Moderator
SW A100 Alkyd Primer
I'm using SW A100 Alkyd primer on a new door for the house and I notice that the brush is dragging quite a bit. I haven't added anything to it. Temp in the house is about 76, and the humidity is about 70%.
Its fresh paint, recently shaken and stirred before and during use. Thoughts?
"My clients’ wishes are the center of my attention." -- David Guido, a contractor in Woodstock, N.Y. New York Times, July 20, 2006 Last edited by Double-A; 10-02-2006 at 06:05 PM. |
Back from the dead...
Trade: Paperhanger/Painter
Re: SW A100 Alkyd Primer
Hire a painter.
Seriously though, I haven't ever used it myself, but if it's dragging a bit, a splash of Penetrol will help. I don't recommend thinner for this either.
Or maybe just brush a little faster? |
#4 | |
My custom title
Draggin primer.. what kind of brush are you using? Oh, and how long does it take you to do one side of the door?
Benn Quote:
#5 | |
...jammin
Trade: Rock Disciple
I'd have to say technique
It's not really a "draggy" primer per say Maybe not loading up that brush enough? Or not fast enough? What kind of door, what material, what brush, and how long does it take you?
Signature Quote Quote:
Moderator
The door is Doug Fir. I'm using a 3" natural bristle brush (red cover contractor one from SW).
Took about 2 hours. I think that's the problem. I'm too damned slow. Bleh.
#7 | ||
My custom title
Re: SW A100 Alkyd PrimerQuote:
Ya umm, I think we know your problem.
Benn Quote:
Moderator
Well, the stuff just didn't seem to want to flow. Call me a poor painter, and I'll agree. Its one thing I enjoy doing. I had some time this afternoon and its sorta like fishing for me. Its relaxing.
But, for some reason today, the painting Gods were just thumbing their noses at my efforts. I couldn't not get the stuff to flow, so it seemed to take forever. I was just wondering if its just me (which I sorta thought it was) or some trick to that particular primer. BTW, its a large exterior door. I have two more to do, but they are smaller, only 3'0" on those.
#9 | ||
...jammin
...except you'll get some dragging if you take to long to paint a door < cue rim shot > Ya you'll have to speed it up to avoid that And anything I've tried marked "contractor" at SWP is over-priced "Home Depot" quality crap Step up to a nice wide, stiff, Corona ....and don't be shy with the A100, it can take some volume You don't really want to thin that stuff, but if you still need some help, try a shot of Penetrol
#10 | |
My custom title
Agreed, though look for a white bristle... they always hold more paint than the black... imo. A100 should flow pretty good with a 3 or 3 1/2 white bristle on the temps you said above.
Benn Quote:
Trade: Painter
It probably flows well at first and bogs down as time goes on. Just keep a can of thinner handy, push the brush down in it, maybe even use a brush comb and spin it out every so often.
White bristles seem to shed more than black, and the white's don't seem to clean up as well as the black. Yes, "seem" is my built in disclaimer. |
#12 | |
My custom title
Seem, heh.. no your right.. they do... but you gotta admit they "give" more and seem to hold more paint than the black bristles....
Benn Quote:
All my personal oil brushes are the white bristle.
Wooster Platinums they are called. |
Moderator
What do you folks do with your used thinner? Does the paint store take it, or do you reuse it somehow?
I've always wondered, but have no idea.
I generally save all my thinner and used motor oil until Earth Day and dump it all down the nearest storm drain.
Earth Day is a busy day for me, because that's the same day I burn all my used tires. Last edited by mdshunk; 10-03-2006 at 12:01 AM. |
White bristle, black bristle, it's the painter who makes it work, or not...
#17 | |
Moderator
BTW Its a 6-panel door. I'll post a pic or two when done, but no close-ups! Hehe, I can only take so much abuse for my inferior technique.
#18 | |
...jammin
A buddy celebrated one Earth Day by burying a car
#19 | ||
...jammin
But most painters should giterdun in 20 or less depending on what material/size I can do it in 7 1/2 minutes, but that's a latex top coat on a 3/0 door Oils primer takes longer
#20 | |
Trade: Builder/Remodeler- Master Electrician
www.copusconstruction.com www.etexasrentals.com www.thelakevoice.com AkA Richard Cranium |
| Drywall primer peeling problem?? | DeanV | Painting & Finish Work | 23 | 02-02-2008 11:02 AM |
| 2 coats of primer on ceiling rather than paint? | Zeebo | Painting & Finish Work | 20 | 12-25-2006 01:05 PM |
| Tinting primer question | icfbunt | Painting & Finish Work | 5 | 12-12-2006 06:44 PM |
| Primer needed on metal garage door??? | Zeebo | Painting & Finish Work | 11 | 08-19-2006 05:35 PM |
| alkyd primer or not | cowtown | Wallpaper | 8 | 08-11-2006 12:46 AM |
