Suggestions
Old 09-17-2007, 09:06 AM   #1
Joewho's Avatar
Trade: Painter
Suggestions
Going back to chicago for a month to do some work for long time customers.
Two story exterior, 3" lap siding. Lots and lots of nails with rust showing through the old paint.
Cost effective suggestions?
Joewho is offline
Old 09-17-2007, 07:01 PM   #2
Painting Contractor
JMGP's Avatar
Rewards Points: 250
Re: Suggestions
Thats unfortunate that the siding was nailed on with improper nails....
To solve the problem:
Clean rust as much as possible... (wire brush, sanding etc)
Apply 2 spot prime coats of a premium oil primer over the nail heads....
OR...
Counter sink the nail heads no more than 1/32"-1/16" you dont want the rounded crater looked when finished...
Spot prime each nail head with a premium oil primer (BM Fresh Start, California Problem Solver)
Apply a thin layer of premium caulking on each nail head...
Apply 2/coats of a premium finish...
JMGP is offline
Old 09-17-2007, 07:19 PM   #3
finlander's Avatar
Trade: General Contractor Residential/Commercial
Re: Suggestions
Rust will probably pop anything you put on it, unless you really clean it and try rustoleum paint. The problem is it is not just the head that is rusting it is the whole nail so eventually rust is going to come through. This is a cheap fix but it will not solve the problem.
You could try setting the nails and a fibreglass bondo, but this would be very labour intensive.
Good luck with that!
finlander is offline
Old 09-18-2007, 09:58 AM   #4
Paint Pro/Faux Artisan
Da Vinci's Avatar
Trade: Painting Contractor/Faux Finisher
Rewards Points: 150
Re: Suggestions
Rust is always a problem. We use phosphoric acid very successfully. In fact, we have a client with an older home in an exclusive neighborhood who calls us because no one else is able to paint here windows and keep the rust from re-appearing (old steel casement windows).
We would scrape any paint off nail heads, use a small artist brush to apply a quick dab of phosphoric on each nailhead. Best to let dry overnight as it chemically transforms rust into zinc oxide (if I recall properly). At any rate, it stops rust very effectively. Prime with a good oil primer over everything and you're ready to go...
Bay Area Painting COntractor
Da Vinci is offline
Old 09-18-2007, 11:20 AM   #5
Chris G's Avatar
Trade: Porch and Deck Builder
Rewards Points: 1,210
Re: Suggestions
Try to sell them on a nice shade of brown? Hey, it's just a thought, could work...
Chris G is offline
Old 09-20-2007, 03:22 AM   #6
Joewho's Avatar
Trade: Painter
Re: Suggestions
I must have lost my settings. I usually get an e-mail when someone replies to a thread. Since I didn't I just ass u me d no one did.
Anyway, I haven't seen the house in a couple of years, but the nail heads aren't showing. I'd have to scrape the paint off all of them. The house is less than 20 yrs. old and probably has the original paint on it.
I like the acid idea. I like pulling and replacing every nail even more, but probably isn't feasable and I won't have any help out there. IF I do pull every nail, I'd replace with galv and not in the same holes. If this does come to pass, what would I patch the hole with?
This also leaves the problem of nails that aren't showing any rust...yet.
Thanks for the fresh ideas guys. Even the suggestion of painting it brown. lol.
It's always a tug of war between doing the very best and compromising. I've seen houses with rusty nails, they do rust all the way through, and rust winds up running out from under the boards. However, if no moisture gets to them, will they continue to rust? Brings up a lot of questions.
Joewho is offline
Old 09-20-2007, 09:00 AM   #7
Da Vinci's Avatar
Rewards Points: 150
Re: Suggestions
Yes, rust never sleeps...once it begins it will continue, even after being covered, though it slows the process down.
Bob
Bay ARea Painting Company
Da Vinci is offline
Old 09-20-2007, 10:26 PM   #8
turning houses into homes
daArch's Avatar
Trade: Wallcovering Installation
Re: Suggestions
What DaVinci said.
Rust is a cancer, to cure it must be removed.
It can be slowed, but not stopped.
I'm amazed no one mentioned Rust-o-leum Rust Reformer. That stuff slows it down and is good for a few years, 3-5.
daArch is offline
Old 09-20-2007, 10:53 PM   #9
Da Vinci's Avatar
Rewards Points: 150
Re: Suggestions
Originally Posted by daArch View Post
What DaVinci said.
We always use straight phosphoric acid (the active ingredient in Rustoleum) because a gallon is about $25, and lasts a long time. It's runnier than rustoleum and penetrates deeper in my experience.
Bob
Bay Area Painting Company
Da Vinci is offline
Old 09-22-2007, 12:51 PM   #10
premierpainter's Avatar
Rewards Points: 250
Re: Suggestions
Sherwin-Williams Pro-Cryll primes over bare wood and will stop the rust. We do all churches with it and have never had a rust issue again.
premierpainter is offline
Old 09-24-2007, 10:41 PM   #11
Da Vinci's Avatar
Rewards Points: 150
Re: Suggestions
SOunds like a viable alternative- have you gone back and checked the work 2-3 years later?
Bay Area Painting Contractor
Da Vinci is offline
Old 09-25-2007, 10:54 AM   #12
Joewho's Avatar
Trade: Painter
Re: Suggestions
D, where can I get phosphoric acid? I was thinking of muriatic.
There are plenty of products to cover up, but I'm worried about what's going on deeper. I'm in Chitown, and will get to see the job today or tomorrow.
Joewho is offline
Old 09-25-2007, 11:19 AM   #13
Da Vinci's Avatar
Rewards Points: 150
Re: Suggestions
No, don't use Muriatic. It will etch, but not chemically transform like Phosphoric, which turns it into zinc oxide. I buy it at Sherwin WIlliams, I think they call it Metal Prep or something like that- just read the label, Phosphoric acid should be first ingredient.
I think BM also sells a brand called Metal Etch which is green liquid and is also phosphoric...
Good Luck.
Bob
Da Vinci is offline
Old 09-29-2007, 11:41 PM   #14
Joewho's Avatar
Trade: Painter
Re: Suggestions
I have SW account, should be no problem.
Joewho is offline
Old 09-30-2007, 07:09 AM   #15
PlainPainter's Avatar
Rewards Points: 250
Re: Suggestions
I have always spot primed with a rustoleum type shop metal primer - has worked great.
PlainPainter is offline
Old 09-30-2007, 04:00 PM   #16
Epoxy Dude
Wolverine-Eric's Avatar
Trade: Industrial Coatings & Linings
Rewards Points: 150
Re: Suggestions
Phosphoric Acid will turn it (rust) into Iron Phosphate... Phosphoric will dissolve rust faster than it will dissolve iron. So, unless you leave it on for a long time it won't really do much damage to the iron.
Specifically, when you react Phosphoric Acid (2 H3PO4) and Rust (Fe2O3), you get Iron Phosphate (2 FePO4) and Water (3 H2O)
Fe2O3 + 2 H3PO4 2 FePO4 + 3 H2O
No Zinc Oxide!
Some things just shouldn't be mixed... like... Kids & Paint
http://www.wolverinecoatings.com/Pic...kids&paint.gif
Wolverine-Eric is offline
Old 09-30-2007, 10:01 PM   #17
MFWIC
Tmrrptr's Avatar
Trade: house painter
Rewards Points: 250
Re: Suggestions
It's nice to get to the bottom of a problem with a clear explanation.
So, what you're saying, is there will be water filled blisters, if you paint too soon, with an impervious coating?
r
Tmrrptr is offline
Old 10-01-2007, 12:07 AM   #18
Rewards Points: 2,000
Re: Suggestions
No Zinc Oxide!
Impressive Professor! I had to write the formulas on my hand to pass chem exams. Isn't that the same as the coating on drywall screws?
neolitic is offline
Old 10-01-2007, 09:17 AM   #19
Da Vinci's Avatar
Rewards Points: 150
Re: Suggestions
No Zinc Oxide!
I stand corrected- it's been 20 years since I first started using that product, so I didn't remember the resulting chemical coating. Most guys at the paint stores scratch their head when you ask for it, let alone explaining the chemical reaction. Thanks for the refresher course professor.
BAy ARea Painting Contractor
Da Vinci is offline
Suggestions for a Sliding Room divider. Viperjts10 Off Topic (Non Trade) 3 01-22-2008 11:48 AM
Suggestions on Marketing New Company Please DNJ6357 Marketing & Sales 7 04-09-2007 09:31 PM
Website re-design comments / suggestions MattCoops Technology 20 01-17-2007 07:35 PM
Have Money. Will buy panel jack. Suggestions? steve-in-kville Drywall 7 10-21-2006 11:42 AM
Anyone have any suggestions 25BRIAN General Discussion 8 11-02-2005 08:37 PM
