Suggested Primer For Knotty Pine
Old 03-12-2012, 11:14 PM   #1
davidanbess's Avatar
Trade: Painting and Decorating
Rewards Points: 266
Hi, what would be your choice of primer for knotty pine, I'm thinking it would have to be an oil based.
Regards David
davidanbess is offline
Old 03-12-2012, 11:29 PM   #2
Sampietro's Avatar
Trade: carpenter/sub contractor
Rewards Points: 150
Re: Suggested Primer For Knotty Pine
I am not a 100% but I think a shellac primer is the best if I remember right.
Sampietro is offline
The Following User Says Thank You to Sampietro For This Useful Post:
jb4211 (03-13-2012)
Old 03-13-2012, 06:59 AM   #3
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
Rewards Points: 1,135
Yep Shellac will seal the knots up the best to prevent bleed through. Zinsser BIN (not BIN 2) is best for this but there are comparable store brands out there like Duron and P&L that work just as well.
gideond is offline
Old 03-13-2012, 08:03 AM   #4
Sampietro's Avatar
Rewards Points: 150
I forgot to mention make sure to wear a respirator maybe a full face mask if you don't like the feeling of your retinas burning out...laughing
Old 03-13-2012, 11:17 AM   #5
hdavis's Avatar
Rewards Points: 4,665
Any shellac product. I use just regular shellac thinned quite a bit (add 50% lacquer thinner) to avoid brush marks, and 2 coat it. It dries fast so 2 coats don't take much time. If you only have a little to do, the spray BIN works well, and I 2 coat just the knots. .
hdavis is online now
Old 03-13-2012, 06:48 PM   #6
Pete'sfeets's Avatar
Trade: house painting and miscellaneous repair
Laquer thinner ? what the heck would you wanna use that! just daft, it's called methyl hydrate or denatured alcohol. What is this Bin 2 , I have never heard of it.. Sounds confusing.. I noticed that there are two Bulls eye , a bulls eye 123 and a weaker one not acceptable for exterior use, I am not sure of the logic , cheaper but not as effective, with so many choices out there why add more
If paint covers all sins ,,,then I guess I should be covered
Pete'sfeets is offline
Old 03-13-2012, 07:57 PM   #7
hdavis's Avatar
Simple, with lacquer thinner I can thin lacquer or shellac. BTW, denatured alcohol is ethanol, not methanol. Ethanol works OK. If that's what you have, use it.
Old 03-13-2012, 11:13 PM   #8
boman47k's Avatar
Rewards Points: 2,006
Oops, I just use Coverstain.
boman47k is offline
Old 03-13-2012, 11:16 PM   #9
The Sheriff
Jaws's Avatar
Rewards Points: 2,944
Sherwin Williams Easy Sand works well, bonding the holes.
Jaws is offline
Old 03-14-2012, 06:54 AM   #10
gideond's Avatar
BIN 2 is a newer product that is suppose to do everything BIN does at a lower price. It doesn't. BIN 2 thins with paint thinner so it's evidently in an alkyd vehicle. It uses a synthetic shellac resin instead of the tried and true bug droppings. The Lac Beetles were evidently not doing well the past year or two and that shot the shellac prices through the roof. BIN2 seems more like an extremely heavy bodied Coverstain to me. Most people I know who have used it say it does cover the smoke damage just like BIN but it's adhesion is not as good.
gideond is offline
Old 03-14-2012, 09:33 AM   #11
Painting & Remodeling
JHC's Avatar
Rewards Points: 516
Seal Lock by inslx is a great primer and replacement that performs close to shellac for sealing knots. Also about $30 a gallon cheaper than shellac. You can get it through your local Benjamin Moore dealer.
http://www.insl-x.com/viewProd.asp?prodID=168
I would probably do a heavy oil coat and spot the knots that bleed through with seal lock. Shellac is just to brittle imo, and the risk of cracking is really high when using it as the initial primer coat.
JHC is offline
Old 03-14-2012, 05:53 PM   #12
I can't imagine why I'd want to use laquer thinner,is it not smelly enough? At least the methyl is odorless , not that I have alot of olfactory sence left.
Old 03-14-2012, 10:05 PM   #13
Rewards Points: 266
thanks one and all
Old 03-14-2012, 11:16 PM   #14
Chris
PowerWash's Avatar
Trade: Pressure Washing
Rewards Points: 192
I am sure that it is not up to a professional painters standards, but, I have had great results from glidden gripper primer on knotty pine.
Pressure Washing Charleston SC - Pressure Washing Summerville SC Pressure Washing: Charleston, Summerville, West Ashley, Mt. Pleasant, Daniel Island, SC - Pressure Washing
PowerWash is offline
Old 03-14-2012, 11:39 PM   #15
The Sheriff
Jaws's Avatar
Coverstain is actually what we use. I asked my brother, I don't paint. Covers the knots better.
Jaws is offline
Old 03-15-2012, 06:58 AM   #16
but cover stain smells so nice. Aw whatever's handy will do, that's how I picked the wifey., but I don't think there's anything guaranteed, a spray of laquer helps too all depends on the freshness,. For the shellac I just keep the brush right in the can, the handle sticks out through the lid ,,till summer arrives anyhow.
Old 03-22-2012, 07:00 AM   #17
Nasty !! I thought the shellac price was bad when it went from 40 all the way to 50 bucks at HD, yesterday I find it is selling for yet another hike of 9 bucks, sixty bucks near. I don't know if the increase is due to more shortage of shellac resin or they are buffering it up next to the increase of other high end products , inflation?, As usual it makes fast work prime to finish but cost is the deciding factor.Need a portable calculator to put in the tool bag.
Old 03-26-2012, 07:33 PM   #18
zorikos's Avatar
Trade: Painter
Rewards Points: 22
I picked up some BIN shellac primer for $26+tax per gallon from my dealer. Home Depot is way more expensive!
zorikos is offline
Old 03-26-2012, 07:45 PM   #19
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
You can buy your own shellac flakes and make your own. My painter makes his own 4 lb.cut. Which is twice as "strong" as the stuff you buy.
Lee Valley sells it.
katoman is offline
Old 03-26-2012, 08:21 PM   #20
hdavis's Avatar
I haven't tried using 4lb for knots. Does it allow 1 coat sealing, instead of 2?
Primer Cracking over Caulk go_hercules Painting & Finish Work 11 01-19-2011 08:39 PM
yellowing pine kubie Painting & Finish Work 3 11-25-2009 05:19 PM
can't get rid of bad primer smell....help please Zeebo Painting & Finish Work 17 12-10-2008 06:39 AM
Primer questions rebar17 Painting & Finish Work 14 10-25-2007 09:51 PM
Best primer for bare pine and/or raw drywall? send_it_all Painting & Finish Work 8 05-04-2007 06:52 PM
