Trade: carpenter
Stop Paint From Chipping/latex Over Oil
Trying to rehab bathroom and need your advice. Five years ago before we bought house the whole interior was sprayed with latex semi white. The paint is holding up well in most places but in the bathroom they sprayed over an oil based semi gloss. The paint there is in fairly good shape but chips off in high traffic areas and when you rub it really hard to clean. No chips larger than a quarter. Basically an adhesion problem. Do I need to scrape all the latex off and clean/sand/prime or could I use a primer like zinnser peel stop to create kind of a hard barrier between layers and stop most of the peeling. Your help in this matter would be greatly appreciated.
Re: Stop Paint From Chipping/latex Over Oil
To make it look good, you need to strip it all and start over.
If the original substrate is letting go, there is no use trying to patch it up. UNLESS you want to venture into very expensise restoration work.
#3 | |||
...jammin
Trade: Rock Disciple
Re: Stop Paint From Chipping/latex Over OilQuote:
Signature Quote Quote:
You need to get down to the seperation layer is. As long as you are going there, might as well go to the base and do a good job.
Trade: carpenter
Hey guys, thanks for answering my question. To scraping I will go.
| why is latex paint peeling?? | Zeebo | Painting & Finish Work | 24 | 05-28-2009 07:59 AM |
| Short Review Of Aura Paint | Riverside Paint | Painting & Finish Work | 30 | 03-07-2009 08:50 PM |
| blistering paint | GWHRsuperhero | Painting & Finish Work | 9 | 03-06-2007 08:43 PM |
| Dealing with flaking paint....help!!!! | Zeebo | Painting & Finish Work | 9 | 11-28-2005 11:03 PM |
