Steel Beams
Old 06-22-2006, 10:02 PM   #1
aspenpainting's Avatar
Trade: int/ext painting
Steel Beams
im looking at painting some steel beams in a city park. there alittle rusted and have been painted before. anybody have any suggestions on the process of painting these. do i have to prime everything or just spot prime the rust?
aspenpainting is offline
Old 06-22-2006, 11:25 PM   #2
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Re: Steel Beams
Clean up the loose rust by abrasion of your favorite flavor, then hit them with ospho, wait 24 hours, prime, paint with a quality oil.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 06-22-2006, 11:57 PM   #3
General Contractor
jensenconstruction's Avatar
Trade: General Contracting and Painting
Re: Steel Beams
What AA said.
jensenconstruction is offline
Old 06-23-2006, 11:31 PM   #4
Re: Steel Beams
ospho?
Old 06-24-2006, 12:50 AM   #5
General Contractor
Re: Steel Beams
Originally Posted by aspenpainting
ospho?
find it here
http://www.ospho.com/
Old 06-26-2006, 10:27 PM   #6
Re: Steel Beams
so apply this stuff then do i need to scuff the beams up or does the oshpo take care of that? do you guys have an oil youd recommend after the prime?
Old 06-26-2006, 11:19 PM   #7
Pro Painter
AAPaint's Avatar
Re: Steel Beams
No, you should clean most rust and rough areas by abrasion before applying the ospho. It will turn any remaining rust back to iron. Then you can actually just finish with SW DTM (direct to metal) alkyd paint.
-AAPaint
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 06-27-2006, 08:59 AM   #8
Painting Contractor
Humble Abode's Avatar
Send a message via AIM to Humble Abode
Re: Steel Beams
That ospho sounds great. AA have you used it before? Have you seen any of the work you did with it after two years?
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline
Old 06-27-2006, 10:06 AM   #9
Teetorbilt's Avatar
Re: Steel Beams
We've used Ospho down here for decades. You can also use it on tools, the body guys use it for vehicle repairs and 1000 other uses.
Albert Einstein
Teetorbilt is offline
Old 06-27-2006, 11:27 AM   #10
Pro Painter
AAPaint's Avatar
Re: Steel Beams
Yes, ospho is awesome stuff. I've been using it on metal since I first started painting. Don't breath the mist off of it though....ack! It causes some kind of chemical reaction though that actually turns rust into iron again...it works right before your eyes, so yes, I can say it works great, and everything I've applied it to and painted has held up quite well.
-AAPaint
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 06-28-2006, 05:32 AM   #11
Tom Rohland's Avatar
Trade: Painting & Pressure Cleaning
Re: Steel Beams
Aspen,
I agree with all of the above. OSPHO is good stuff.
Protect yourself and the surrounding areas.
Just use a wire brush or other means to remove ALL loose paint and rust scale. You DO NOT have to remove tight rust.
Clean off dirt, grease, etc.
Apply a coat of OSPHO by brush or spray. Apply two coats where the rust is heavy and let it dry overnight.
Brush off loose powder.
Then just paint the steel poles with an oil base primer and paint like AA suggested.
Hope this helps.
Tom Rohland, Jr.
Ranger Painting & Pressure Cleaning, Inc.
Lake Mary, Florida
PS When applied to rusty surfaces, OSPHO causes the rust to turn black which is iron phosphate.
Tom Rohland is offline
Old 07-02-2006, 12:31 PM   #12
Re: Steel Beams
thanks for the advise guys ill let you know how it goes
FS 6"x10"x14' rough saw'n pine beams gsp Contractor Swap 2 06-05-2007 01:10 PM
Rotten Beams - must replace MHMConstruction Framing 5 03-17-2007 02:14 PM
Rotten Beams - must replace MHMConstruction Remodeling 8 03-05-2007 04:45 PM
steel beams lowell5slide Painting & Finish Work 10 06-09-2006 04:41 PM
Help with painting rough cedar beams jgladdy Painting & Finish Work 9 04-21-2006 04:18 PM
