Staining Wood Filler
Old 08-30-2007, 06:04 PM   #1
Steve Richards's Avatar
Trade: hack painting
I stained and lacquered some oak laminate doors years ago (interior- office building), and they've chipped over time, mostly at the bottom edges. So I'm going to use a filler, sand, and then (try to) touch up the stain...
I plan to sample Wood Dough, Bondo, and ?..and see if I can get something to take the original stain close enough to at least be passable.
In your opinion/experience, Which filler(s) accepts stain the best?
Thanks!
Steve Richards is offline
Old 08-30-2007, 08:41 PM   #2
Remodeler
MinConst's Avatar
Re: Staining Wood Filler
saw dust and glue. White glue. There is also burn in sticks. Used for repairs.
Paul
Minichillo's Construction
Website
I will never leave you hanging!
MinConst is offline
Old 08-31-2007, 02:02 AM   #3
27yrsPaintandFinefinishes
Runamuk's Avatar
Trade: paint talk
I never use "wood filler". I stain and seal then use color putty to fill the holes. I can adjust the color putty as needed to light and dark spots then seal it in with 2 coats of lacquer.
Rick
Runamuk is offline
Old 08-31-2007, 08:29 AM   #4
Thanks Paul, Burn in sticks look interesting.
I've also heard of, and will look further at "Laminate repair paste"
Rick...you'd use color putty to repair chips in laminate on doors?
I use it for nail holes, and maybe miter cuts, but that's about it.
Old 08-31-2007, 10:36 PM   #5
Runamuk's Avatar
Trade: paint talk
DOH~ sorry missed the laminate part. It really depends on how big the problem is and where on the door it is. I'll not use color putty for anything bigger than a pin nail hole, nor anything that will continuously suffer abuse.
Rick
Runamuk is offline
Old 09-01-2007, 12:54 PM   #6
Paint Pro/Faux Artisan
Da Vinci's Avatar
Trade: Painting Contractor/Faux Finisher
PAul, do you have trouble with the white glue/sawdust patch accepting stain?
Bay Area Painting Contractor
Da Vinci is offline
Old 09-01-2007, 08:35 PM   #7
Remodeler
MinConst's Avatar
Fine sawdust and mix the stain in while wet. Sand and it will take stain again. Not the best way but doable. I've done touch up work for years and this works. Maybe saw dust was a poor example. More like sanding-dust. Also band saw dust works but not for finish work. Makes a very strong repair on cracked wood, once dry it will accept nails. Also it's best to use the dust from the same species of wood.
Paul
Website
MinConst is offline
pls help.. wood filler problem cynthiann Painting & Finish Work 5 03-19-2009 01:45 PM
which wood filler? rocco Carpentry 10 03-18-2009 12:40 PM
Wood Filler navco1390 Painting & Finish Work 3 01-26-2007 10:31 AM
wood filler recommendation on crown molding JRicker Finish Carpentry 14 01-24-2007 08:59 PM
wood filler vs. caulk for trim fabiano Painting & Finish Work 13 07-29-2006 03:09 PM
