Staining A Pine Door Dark
Old 05-12-2007, 11:53 AM   #1
fast pasquale's Avatar
Trade: Hardwood flooring contractor
Got a customer who's front door i sanded down and stained golden oak. He wants it darker. He's most likely going to go for a dark brownish stain and ive always had problems staining pine a dark color. I've used the wood conditioner and it never seems to help... still turns out blothchy. What is the trick to staining pine dark?.. I was thinking sand it to 150 or 180 grit to try to close off some of the grain so it won't absorb so much stain??... Thanks in advance!
Chris Frate
Pasquale Floors
fast pasquale is offline
Old 05-12-2007, 04:59 PM   #2
Joewho's Avatar
Trade: Painter
Re: Staining A Pine Door Dark
There is no trick. Pine will blotch. If the owner wants the door to look like oak, he should buy oak. Some pine will blotch more than other pine, it's out of our hands.
Silly people spend a few bucks on a pine door, pay a painter the equivelant of an oak door to make it look like oak.
Joewho is offline
Old 05-12-2007, 07:13 PM   #3
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
Joe, what are your feelings about the gel stain on pine?
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company.
dougchips is offline
Old 05-13-2007, 07:04 AM   #4
gel stain or waterlox (tung oil) mixed with stain seems to be a popular response
Chris Frate
Pasquale Floors
Old 05-13-2007, 08:44 AM   #5
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
A trick to help stain wood dark (not sure if it will work for pine) is to 'pop the grain'. Wipe the door down with a wet rag which will raise the grain and open the pores to accept more stain.
ProWallGuy is offline
Old 05-13-2007, 08:57 AM   #6
Professional Painter
Richard's Avatar
Trade: Owner/Operator
ain't that the truth
Rich
Richard is offline
Old 05-13-2007, 04:14 PM   #7
Joewho's Avatar
Trade: Painter
I've never been a fan of gel stain for anything. But, that's just me, I've seen comments from other guys here that know how to use it, maybe for faux graining, or I thought there was something about it for certain types of doors.
I don't see how gel and stain mix will help any more than just applying 2 or more coats of stain. But, again, I don't know everything.
Joewho is offline
Old 05-13-2007, 06:03 PM   #8
My custom title
Brushslingers's Avatar
Trick to making PINE take dark stain is thus.... wipe it down real good with spirits, dry, then oil, then stain.
Ain't gonna look like oak but, will get fairly dark that way.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 05-14-2007, 06:23 AM   #9
when you say "then oil"... what do you mean???
Chris Frate
Pasquale Floors
Old 05-14-2007, 11:41 PM   #10
My custom title
Sorry, witch hazel... or something like that, linseed is a little too much oil, watched my dad use mineral oil once even...
Benn
Old 05-15-2007, 10:18 PM   #11
painter14619's Avatar
Trade: Painter
This is not the customary way to stain a door, but I put on a sanding sealer to close the grain, then lightly sanded the door, then added the stain to desired depth, then sanded, and put a poly as the finish coat and it looked pretty damn good.
painter14619 is offline
Old 05-16-2007, 10:49 PM   #12
troubleseeker's Avatar
For any chance of not blotching, the pine must be completely sealed. This usually takes at least three coats of sanding sealer, with a light sanding between coats to smooth it out. Those pre stain conditioners are basically just an oil, and the theory is that the soft grain will absorb more oil than the hard, so it will even out the amount of stain accepted. Works fairly well on a piece of uniform wood, but not something with such wide range of grains as pine. The best way to get the uniform color you want, provided the customer wants to pay for it, and you have a sprayer, is to prep as above, then tint a batch of sealer to the desired color and mist on a couple of light coats. Very lightly sand when dry, and protect with marine spar varnish. If no sprayer, take your time with a brush. For top notch protection use true spar varnish manufactured by a marine paint company such as Woolsley, etc, available at a boating center. The so called spar varnish from a non-marine line of products like Minwax pales by comparison in the amount of uv inhibiters and high quality resins. Not a cheap process though.
troubleseeker is offline
Old 05-18-2007, 03:55 PM   #13
Joewho's Avatar
Trade: Painter
Put you back into it, man. Get a rag and rub the stain into the wood, crossgrain. HARD. After it dries, do it again.
Sealers go contrary to getting the wood to absorb the stain. Raising the grain will open the pores, but then you have raised grain. Has to be sanded. Might get away with raise the grain, stain, seal with sanding sealer full strength, sand and finish.
Get a freakin can of toner.
Joewho is offline
Old 05-22-2007, 11:26 PM   #14
MFWIC
Tmrrptr's Avatar
Trade: house painter
Trouble has got the ticket!
All you gotta do is get the pine client to pay .
r
Tmrrptr is offline
pine and others for exterior trim 415moto Carpentry 35 05-15-2011 10:58 PM
Pine floors and dogs=problems ron schenker Flooring 12 03-05-2007 05:47 PM
Staining Rough Cedar lpp Painting & Finish Work 12 05-05-2006 10:45 PM
Staining interior Cherry trim cowtown Painting & Finish Work 8 04-25-2006 09:41 PM
Water staining on exterior stucco cutnroller Painting & Finish Work 13 03-17-2006 05:22 PM
