Stainable Wood Patch
What do you use that's
1. Stainable 2. Sandable for pre filling wood prior to staining? |
Painting Contractor
Re: Stainable Wood Patch
Hummm...
It all depends on what kind of wood it is to be stained... and this is for "only" tiny patching... If there are large areas that need patching.. replace the wood... You could try a product called Zar Wood Patch... it is used for "Lighter" colored wood...but you can mix a bit of stain in with it... If you are just filling nail holes use the proper putty for that... Apply 1/coat of clear finish first... then fill nail holes.. (no smudges)... Im sure you already new that.... Joe |
I haven't tried anything as yet that will take a stain to match the surrounding wood. I like the crayon-type fillers and also do the filling only after the finish has been applied. If a match is impossible (probably will be), I go darker than the stain as it makes it look more like something in the wood, rather than a filled nail hole.
If you really want to get fussy, you can apply a little stain over your patch after you have filled and feather it in with a small artists brush. On stuff like dark stained oak, it's tough to beat a wax filler followed by a black magic marker.
If you have integrity, nothing else matters. If you don't have integrity, nothing else matters. ~Alan Simpson
Remodeler
Sawdust and glue is a very good filler. White glue not tightbond. White glue dries clear. Saw dust from a band saw is what I find to be the best size. And of course use saw dust from the wood your filling. It sands fairly easily and takes stain like the surrounding wood. I also use the filler sticks but if the sawdust is available I will use it.
#5 | |
Re: Stainable Wood PatchQuote:
White glue may dry clear, but glue doesn't except stain so how do you get around that? |
painterofeverything
plain old bondo takes stain quite well also.
The latest edition of Shop Notes magazine has a write-up on a new glue that will take a stain. It's Stainable Wood Glue by Pro Bond. The pictures showing the results look pretty impressive.
Maybe using this, mixed with some same-species wood dust would do the trick.
Trade: Builder/Remodeler- Master Electrician
I used to use "rock hard" and mix it with stain. Used to work pretty well.
www.copusconstruction.com www.etexasrentals.com www.thelakevoice.com AkA Richard Cranium |
#9 | |
Remodeler
Chief Toilet Mover
Trade: Bathroom Remodeling
Hide glue and the saw dust of the wood you are patching.
#11 | |
Pro Painter
I've used the glue and sawdust method numerous times, and it's quite effective. Your patches become nearly invisible this way...
Trade: REMODELING CONTRACTOR
__________________ Mike Finley Ditto. Steve Unkie. |
| Exterior wood patch | igorsoccersocce | Painting & Finish Work | 13 | 10-29-2009 12:59 PM |
| New kind of Pressure Treated wood | karma_carpentry | Carpentry | 23 | 08-21-2008 09:06 AM |
| Pressure Treated Wood | rjordan392 | Carpentry | 4 | 05-28-2007 02:23 PM |
| Wood people I need your help | Floorwizard | Flooring | 11 | 05-18-2006 09:07 AM |
| Really Dark Wood...Primer/Application Q | slickshift | Painting & Finish Work | 13 | 04-28-2006 04:47 PM |
