Trade: int/ext painting
Stain/lacquer Gun
hey guys thinking about getting a sprayer for stains and clearcoat any recommendations. dont need to use it that often just one for when i do come across woodwork.
Re: Stain/lacquer Gun
This is an Asturo HVLP conversion gun that I've used for 4-5 years. It does a great job.
Attachment 2354 The choices are vast. If you are only going to use it ocassionally, you can pick up a cheap one (Campbell-Hausfeld) to get the job done. The most important thing is to keep it clean and practice on scrap before shooting the real thing.
If you have integrity, nothing else matters. If you don't have integrity, nothing else matters. ~Alan Simpson
Binks is #1, an inexpensive knockoff is Nesco and many of the parts interchange with Binks. In furniture, you won't know the difference.
To convert it to HVLP, you have to split the air and add 2 regs. Pressurize the pot to 3-5 PSI and back off on the gun pressure. You will have to play with this. Done properly, this system will shoot polyester gel coat and resin, latex and the mediums that it was designed for. It takes some practice.
General Contractor
Trade: General Contracting and Painting
We use the Binks Mach 1 with a pressure pot setup
can i use the titan 440 i already have and just change the hose and gun. a guy told me that i would be ok doing that its for trim and maybe cabinets.
We use airless sprayers for our woodwork. For lacquer we use a 4-12fine finish tip. For varnishes we use 4-11. We also use the same for cabinets
