Stain Blockers
Old 07-26-2006, 07:28 AM   #1
Vermy's Avatar
Stain Blockers
I have a smoked (cigarette) stained ceiling to spray and I can't use anything oil based because of the smell and fumes (customers request). I'v never used any water based stain blockers. But i'm looking at the zinsser products. Anybody here have any experience with water-based stain blockers? do they actually work? and are they really odourless?
Vermy is offline
Old 07-26-2006, 07:47 AM   #2
Painting Contractor
Humble Abode's Avatar
Trade: Painting Contractor
Send a message via AIM to Humble Abode
Re: Stain Blockers
Zinsser has a great oderless stain-blocking primer called... Oderless.
http://www.zinsser.com/product_detail.asp?ProductID=123
What are you washing the stains with prior to priming them?
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline
Old 07-26-2006, 08:10 AM   #3
SSP
SSP1's Avatar
Re: Stain Blockers
Zinnsser does work well I have also used SW Pro-Block and have had
great success with both. Clean the best you can (it's hard to do much of anything with cigarette tar though)
SSP1 is offline
Old 07-26-2006, 12:54 PM   #4
DeanV's Avatar
Trade: Painter
Re: Stain Blockers
Remember that the Zinnsser odorless is not an alkyd or oil product, if you read the label it is an acrylic that uses mineral spirits as the solvent. This may do the over watersoluble stains as the mineral spirits might keep it from bleeding through the primer while it drys but if you feel a true oil is needed, this is not the product (and I do not know what is a better option though). For some people I have found that the odor from shellac is not as objectionable, but what I like is that the alcohol fumes seem to dissapate quicker than the fumes from an oil primer.
DeanV is offline
Old 07-26-2006, 01:05 PM   #5
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Send a message via Yahoo to painterofeveryt
Re: Stain Blockers
also please remember that with any stain blocking primer,most want you to wait 24 hours before topcoating to ensure proper holdout ! thanks
painterofeveryt is offline
Old 07-27-2006, 06:54 AM   #6
Vermy's Avatar
Re: Stain Blockers
Thanks for your help guys. I'm probably gonna give that "oderless" stain blocker a try. I still don't have much confidence in water-based stain blockers but in this situation I dont have much of a choice.
Vermy is offline
Old 07-27-2006, 10:28 PM   #7
My custom title
Brushslingers's Avatar
Re: Stain Blockers
The old time fix is a lot simpler than washing stains... and it's not oil. Shellac based primers are waterborne, and will cover ciggie tar as well as fire damage in one shot without much of a "fume".
Brushslingers is offline
Old 07-27-2006, 10:31 PM   #8
DeanV's Avatar
Trade: Painter
Re: Stain Blockers
I have never seen a shellac that uses water as the carrier, I thought they all used alcohol, and therefore are not waterborne by definition. If there is a way to dissolve the shellac into pure water, that would be great and I would have the sanding sealer I am looking for for waterborne finishes.
DeanV is offline
Old 07-27-2006, 10:38 PM   #9
My custom title
Re: Stain Blockers
Most Shellac primers/sanding sealers... are cleaned with water and ammonia, which is not exactly waterborne, but... We have used Shellac based primers for 40 years in fire damaged homes, over glossed doors and cabinets, etc. I use Shellac based sanding sealer for ALL wood, reguardless of oil or latex finish simply for the durability.
Old 07-27-2006, 10:44 PM   #10
My custom title
Re: Stain Blockers
Sorry, it's late and I wasn't thinking. Zinnser, Bull's eye. Spray or roll it on, clean it up with water and ammonia, 2 parts water to 1, DO NOT GET sudsy.
Best opaque stain product??? Barbara Masonry Picture Post 2 07-11-2007 07:18 PM
Recoating with Stain on Walls plazaman Painting & Finish Work 5 06-05-2007 09:58 PM
Pricing stain work airborneSGT Painting & Finish Work 3 03-27-2007 08:36 PM
Stain b/4 or after installation??? pitterpat Painting & Finish Work 10 10-09-2006 07:15 AM
Stain trim b/4 or after installation pitterpat Carpentry 3 10-08-2006 11:09 PM
