Spraying Waterbourn Clear
Old 11-06-2007, 07:31 PM   #1
painterman's Avatar
Trade: Historic Restorations
I have a job coming up to spray(with HVLP) some new cabinets with Valspar water based clear. I have sprayed regular latex paint but never this product. Any thing I should beware of before I start.
painterman is offline
Old 11-06-2007, 07:48 PM   #2
DeanV's Avatar
Trade: Painter
Re: Spraying Waterbourn Clear
I have not done a lot of spraying with the WB clears, but did once with airless and once with HVLP. The first coat dries fast and can be recoated soon. Do not sand until after the second coat, this will help minimize future grain raising. It will also sand better if you let the second coat sit overnight than if you try to rush it too much. I would guess that you are looking at 4 coats with HVLP to get a nice build, but I am not familiar with that particular product.
DeanV is offline
Old 11-09-2007, 11:34 PM   #3
Joewho's Avatar
Trade: Painter
BUBBLES.
Joewho is offline
Old 11-09-2007, 11:44 PM   #4
It's all about the Avatar
woodmagman's Avatar
Trade: I have no face!
We spray all our cabinets and wood work with airless.....HVLP is sitting on the shelf, it just puts it on to slow and the heat from the turbine can dry the material as it comes out of the gun.
woodmagman is offline
Old 11-10-2007, 10:18 AM   #5
DeanV's Avatar
Trade: Painter
I use a compressor powered HVLP, so heat is not a problem.
DeanV is offline
Spraying pressure, tips and mostly technique bgpainter Painting & Finish Work 11 08-12-2008 11:39 PM
insurance for spraying exteriors Traditions Painting & Finish Work 5 05-14-2007 11:07 PM
Texture spraying painterman Drywall 3 11-08-2006 07:08 PM
spraying has ruined my brush and roll estimating Traditions Painting & Finish Work 11 09-15-2006 04:31 PM
spraying on stilts!!!!! drywall Drywall 5 07-06-2006 11:51 PM
