Spraying New Drywall
Old 12-20-2008, 01:34 PM   #21
A bit abrasive.
WisePainter's Avatar
Re: Spraying New Drywall
The pump sounds properly "winterized".
My advice: Hire a real painter to do it.
WisePainter is offline
Old 12-20-2008, 06:53 PM   #22
Workaholic's Avatar
Trade: Painting Contractor
Yep i agree sounds ready for storage.
Sean
Workaholic is offline
Old 12-21-2008, 12:50 AM   #23
President of the world
world llc's Avatar
Trade: general contractor
storage back in the box it came in along with it's place back on the shelf at home depot and your money back
world llc is online now
Old 12-22-2008, 07:15 PM   #24
vandy
vandyandsons's Avatar
Trade: painting, decorating, wallcovering
ok,
heres what you do.
using a 415, 417, 515, or 517, spray and backroll your primecoat on the walls first, then you prime and finish your cielings via spray and backroll, then you do your enamel package which I like a 210 for trim and doors, but I will occasionally use a 310 on doors too. finally, vigorously sticksand your walls, dusk and mask off your enamel work where necessary, and cut and roll your finish coats on the walls as needed.
fyi: heres how you read a spray tip. double the first number, then the first number indicates the width of your fan from 12" away from the surface. the higher the number the wider your fan the second two numbers indicate the amount of material discharging. the bigger the numbers, the heavier the material
ex: 415 (8" fan with a .0015 orfice)
vandyandsons is offline
Old 02-10-2009, 08:27 PM   #25
Grand Rapids Remodeling
Paulie's Avatar
I'm a remodeler that does a lot of drywall work. I've always rolled the primer. Primer is always included in my price (nothing like a coat of paint to show a mistake). I have been agonizing over putting out the $ for a airless. My painting buddies say get a 440 i but I see them buying expensive tips and taking a lot of time taping off. I ask is it worth the $ for primering drywall. I'll leave the colors for the homeowners or real painters.
Paulie is offline
Old 02-10-2009, 09:01 PM   #26
Side Effects May Vary
ModernStyle's Avatar
Trade: Professional Painting
Go do an intro, then comeback and start your own thread, trust me it will go over alot better with the fella's around here if you do.
ModernStyle is offline
Old 02-10-2009, 09:24 PM   #27
Paulie's Avatar
Paulie is offline
Old 02-10-2009, 09:35 PM   #28
Wolfgang's Avatar
Trade: Painting & Remodeling
Originally Posted by vandyandsons View Post
ok,
heres what you do.
Thanks for setting him straight. Makes me wonder what his area of expertise is cause it sure aint sprayers.
Wolfgang is offline
Drywall Scratches - Level 5 Smoothwall HUNG BY FOOT Drywall 15 03-10-2009 06:19 AM
drywall romaina-europe crystal Drywall 20 02-08-2009 05:28 PM
Wet Drywall copusbuilder General Discussion 17 11-14-2008 07:38 PM
Will this drywall thing ever end?! Dan V. Drywall 19 10-29-2008 11:55 PM
How much advantage is 5/8 drywall over 1/2"? Jim S. Drywall 2 08-26-2008 11:52 AM
