Trade: Technical
Spraying New Basement
(No Carpet, new Drywall - orange peel, same color ceiling and walls, high-gloss trim)
I'm in the process of finishing my basement and want to rent a sprayer from HD to prime and paint. What are the disadvantages of spraying the primer and paint prior to installing the trim, doors, and baseboards? Can it be done? THANKS. |
Trade: Painting Contractor
Re: Spraying New Basement
Yes you can do it. I myself wait utill the trim is up, then i prep my trim, then spray my ceilings then prime and finish my trim. Then i move to then walls.
I wait untill the trim is finished because it works best for me. Also if i went in and primed the ceiling and walls, the trim carpenters/wood butchers would have problems finding the studs. If you are doing your own trim then it won't matter much.
Sean |
Painting Contractor
Yup, spray and backroll before trim is the easiest way.
If love is blind, why do they make Lingerie? |
Trade: Technical
Can I spray the trim and doors prior to install, and then putty and touch up after they've been affixed? (assuming the studs are marked on the concrete floor) Would touching up the trim (with a brush) be noticable after previously spraying? Keep in mind, I'm not expecting professional quality, this is a DIY afterall.
#5 | |
...jammin
Trade: Rock Disciple
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs. Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/ We apologize for any inconvenience that this may have caused. This thread has been closed.
Signature Quote Quote:
| Help Water in Basement | LG2720 | Construction | 12 | 01-17-2007 02:40 AM |
| Brick Footer and Water Proofing | emtaboy | Excavation & Site Work | 24 | 07-24-2006 09:48 PM |
| HELP! Basement floor disaster | Profiter | Construction | 5 | 07-11-2006 09:01 PM |
| Wooden Basement? | LWF | Construction | 21 | 05-08-2006 04:17 PM |
| Landscape solution to basement moisture problem | RJC | Construction | 3 | 11-21-2005 01:34 AM |
