Spraying Finish Coat On Stained Trim
Old 04-26-2010, 08:22 PM   #1
kamileoosh's Avatar
Trade: painting contractor
Hi guys, would need a little info here on spraying finish clearcoat on trim.
I have a long experience with spray painting the trim. I have graco ultra 395. Usually I use latex (ocasionally oil) semi-gloss with 310 tip, primer where necessary and two coats of finish and get very nice results.
However I do not have any experience with spraying polyurethane/varnish/laquer clearcoat. I have a nice big basement with knotty alder doors for staining and the rest of trim for painting.
What kind of product do you use on stained doors? What tip, pressure?
When I tried polyurethane I had bad results. Either drips or uneven finish.
Maybe Hvlp sprayer? If yes what type of gun, company, etc.
Thanks in advance.
kamileoosh is offline
Old 04-26-2010, 08:42 PM   #2
jchomes's Avatar
Trade: residental contractor
Rewards Points: 75
Re: Spraying Finish Coat On Stained Trim
I own cap spray stage 4 turbine hvlp runs about 1,000 bucks but works great you can buy tip kits I can spray latex,oils, stains, polys no problem some thining required depending on product for latex thay make flowtrol oils I think its called flood or you could use water or thinner but flowtroll and flood are suposed to make product lay flatter and smoother never had runs with the hvlp you can turn it down and dial it in to spray a pencil with mabee qrt inch over spray but if doing alot of spraying may need a hopper or pot qaurt cup dosent last long
jchomes is offline
Old 04-26-2010, 09:25 PM   #3
RCPainting's Avatar
Trade: Painting in Utah
Wiping stain, sanding sealer, 2 coats lacquer, sanding and tacking between coats. Use a 440i. Make sure you get every bit of the door, the knobholes, etc or it voids the warranty.
Some pictures here
RCPainting is offline
Spraying Mud, Skim Coat , Etc... plazaman Drywall 16 02-17-2012 09:28 AM
Indoor residential trim spraying Droosky Painting & Finish Work 2 10-07-2009 06:24 AM
Spraying with Fuji Q4, but not working, need help CREATE NYC Painting & Finish Work 1 09-29-2009 10:10 PM
spraying trim eric wayne Painting & Finish Work 7 06-05-2009 10:08 PM
interior pre primed trim..one coat regal Painting & Finish Work 8 10-22-2007 07:21 AM
