Spraying Crown Moulding? - Page 2 - Painting & Finish Work - Contractor Talk
Old 01-24-2018, 05:24 PM   #21
JBH's Avatar
Trade: design/build
Rewards Points: 54
Re: Spraying Crown Moulding?
@Ohio painter - I use pre-painted white hinges. Since 99% of the trim paint I use is white, no masking thus required. (If a client wanted different hinges, I would just spray with the white ones and replace them later with the client's preferred type - still easier than masking.)
@ Xtrememtnbiker - My current project is an 1800+ sq ft bungalow ground floor gut/reno + top-up addition. Not a huge house, but not tiny either. All trim and doors (except for the bathrooms, which were brushed/rolled as masking the already-tiled floor would be too much of a hassle) were sprayed in about an hour. With just a plywood subfloor elsewhere in the house, no masking/dropcloths were required - another major timesaver.
JBH is offline
The Following User Says Thank You to JBH For This Useful Post:
Ohio painter (01-24-2018)
Old 01-24-2018, 05:27 PM   #22
avenge's Avatar
Rewards Points: 2,948
Originally Posted by JBH View Post
In any newly-constructed space (i.e., all new drywall, all new trim) I use a Titan sprayer to do all the cutting in - walls, ceilings, trim. Then one coat satin latex on all trim (doors, jambs, casings, baseboards, crowns). No masking, not even window glass (a single-edged razor easily deals with the overspray). Then brush/roll the rest - I've never have a problem with the sheen on trim overspray showing through flat ceiling or wall paint.
Frankly I have no idea how anyone paints trim with a brush. With a sprayer I can paint every door and all trim in an entire house in an hour.
Bet you really have some really fine cut in lines with a sprayer. WTF
avenge is offline
Old 01-24-2018, 05:29 PM   #23
avenge's Avatar
So you paint the hinges? Again...WTF
avenge is offline
The Following User Says Thank You to avenge For This Useful Post:
Lettusbee (01-25-2018)
Old 01-24-2018, 07:47 PM   #24
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,574
House flipper? Unless you're just dusting with paint, I can't imagine the hinges take the paint well. And there won't really be paint on the trim next to them.
Standard new construction isn't that much different than what you do, but at least they take the doors off. And mask windows.
I helped someone flip 7 houses when I lived in Tacoma 18 months and didn't want to start my own business for such a short stay. Similar quality, similar time frames. 45 day whole house, mostly just me working. We didn't do bad work or hide things, we just rushed through stuff. Basically half the cost of the mid-range work I do now. New owners were always happy. Still better stuff than what's out there.
Golden view is offline
Old 01-24-2018, 09:32 PM   #25
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,592
I sprayed the crown 2 coats today. Looks great! Will roll out the ceilings tomorrow.
Sent from my SM-G930W8 using Tapatalk
heavy_d is offline
Old 01-24-2018, 10:11 PM   #26
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 1,646
I miss my little Graco cordless sprayer.
I am looked at the new ones with DeWalt batteries
cedarboarder is offline
Old 01-25-2018, 06:28 AM   #27
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
That's the one I have. It's great!
heavy_d is offline
Old 01-25-2018, 11:20 PM   #28
Mordekyle's Avatar
Rewards Points: 3,540
I just picked one up yesterday.
I'll see how it goes tomorrow.
Mordekyle is online now
Old 01-26-2018, 07:31 AM   #29
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
https://www.instagram.com/p/BeW4ggbh6NU/
heavy_d is offline
The Following User Says Thank You to heavy_d For This Useful Post:
Sir Mixalot (01-27-2018)
Old 01-26-2018, 07:32 AM   #30
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
The 310 tip is still a little big I feel for crown and base so I may pick up a 208.
heavy_d is offline
Old 01-26-2018, 08:10 AM   #31
edward trowelhands
Trade: Diplomat
That's a FF LP tip, right? At least on a big rig you can really turn down the pressure and not get tails, and paint pretty slow.
Sir Mixalot (01-26-2018)
Old 01-27-2018, 07:01 PM   #32
Trade: Workaholic
what size batteries does it come with?
have you been able to run a battery dead since you are not spraying much?
Crown moulding installation Xtrememtnbiker Finish Carpentry 437 05-18-2015 01:09 AM
Clients occupying crown moulding work area...? kevbo Finish Carpentry 52 07-31-2013 08:48 PM
calculating crown spring angle Mrmac204 Finish Carpentry 12 12-26-2012 07:08 AM
Festool 494369 crown stops for kapex BCConstruction Contractor Swap 4 10-02-2012 09:37 AM
Crown moulding in Kitchen w/ cabinet crown JTW Finish Carpentry 42 07-06-2010 08:26 PM
