Spraying Crown Moulding?
Old 01-23-2018, 07:26 PM   #1
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,438
Hey guys. Usually I brush crown moulding but recently got the new Graco cordless spray gun and want to spray the crown. It will already be installed. I also have to paint the ceiling (roll) so what order would you do things in?
Btw, the walls are already painted but I don't mind cutting in under the crown.
Should I spray the crown two coats (semi gloss) with no masking, and have the paint feather onto the ceiling and wall, then once dry, roll the ceiling both coats and cut into the crown? In this scenario, will the semigloss flash through the flat ceiling paint? This is my fear.
Or should I paint the ceiling, And then mask above and below the crown and spray both coats of semi gloss?
I want to do the first option but am worried about flashing. Thoughts?
Sent from my SM-G930W8 using Tapatalk
heavy_d is offline
Old 01-23-2018, 07:47 PM   #2
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Re: Spraying Crown Moulding?
Or maybe I should just brush the crown. I don't know if I can justify the expense of all the extra masking that will need to be done to spray the crown in a finished home.
heavy_d is offline
Old 01-23-2018, 08:25 PM   #3
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,212
I always spray trim first and it doesn't flash. But cutting at the ceiling sucks. I'd let the crown dry thoroughly and mask with something like 2080 before rolling the ceiling.
Golden view is offline
Old 01-23-2018, 08:44 PM   #4
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
How many coats do you spray, And semi gloss?
heavy_d is offline
Old 01-23-2018, 10:15 PM   #5
JBH's Avatar
Trade: design/build
Rewards Points: 46
In any newly-constructed space (i.e., all new drywall, all new trim) I use a Titan sprayer to do all the cutting in - walls, ceilings, trim. Then one coat satin latex on all trim (doors, jambs, casings, baseboards, crowns). No masking, not even window glass (a single-edged razor easily deals with the overspray). Then brush/roll the rest - I've never have a problem with the sheen on trim overspray showing through flat ceiling or wall paint.
Frankly I have no idea how anyone paints trim with a brush. With a sprayer I can paint every door and all trim in an entire house in an hour.
JBH is offline
Old 01-23-2018, 10:19 PM   #6
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 614
Really?
Xtrememtnbiker is offline
The Following 3 Users Say Thank You to Xtrememtnbiker For This Useful Post:
avenge (01-24-2018), Big Johnson (01-24-2018), Golden view (01-24-2018)
Old 01-23-2018, 10:30 PM   #7
GC/carpenter
Californiadecks's Avatar
Rewards Points: 6,966
Mike.
_______________
Californiadecks is online now
The Following User Says Thank You to Californiadecks For This Useful Post:
tang (01-24-2018)
Old 01-23-2018, 10:32 PM   #8
edward trowelhands
Trade: Diplomat
2 coats Benjamin Moore Advance. Satin or Semi.
heavy_d (01-24-2018)
Old 01-24-2018, 05:19 AM   #9
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Its not newly constructed. It's a remodel. Thanks for saying it won't flash through. I'm going to spray the crown first then.
heavy_d is offline
Old 01-24-2018, 06:45 AM   #10
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,137
I like to spray the crown last. I cover the ceiling and wall next to the crown with paper using my 3M masking machine. This technique results in a glass like finish with "Perfect lines". You will be the man!
Sir Mixalot is offline
The Following 5 Users Say Thank You to Sir Mixalot For This Useful Post:
Golden view (01-24-2018), heavy_d (01-24-2018), KAP (01-24-2018), Mordekyle (01-24-2018), Philament (01-24-2018)
Old 01-24-2018, 09:12 AM   #11
KAP's Avatar
Trade: Custom
Rewards Points: 26,772
Same... in most cases, we always paint whatever's closest (protruding) to us last...
KAP is offline
The Following 2 Users Say Thank You to KAP For This Useful Post:
jlhaslip (01-24-2018), Sir Mixalot (01-24-2018)
Old 01-24-2018, 10:13 AM   #12
tjbnwi's Avatar
Rewards Points: 2,896
Get a masking machine. Only regret you'll have is not getting one sooner.
tjbnwi is online now
Old 01-24-2018, 10:37 AM   #13
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
What's a masking machine? I do have a 3m hand masker.
heavy_d is offline
Old 01-24-2018, 10:40 AM   #14
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Thanks. If I was brushing the crown I would do it last. But I really want to try my new Graco cordless for this. I got a new 310 tip for it. And I'm rolling the ceiling.
heavy_d is offline
Old 01-24-2018, 11:12 AM   #15
tjbnwi's Avatar
A car day holdover...
https://www.eastwood.com/eastwood-ma...caAj7KEALw_wcB
They make single roll units also.
Old 01-24-2018, 11:13 AM   #16
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
That thing is awesome but I mostly build decks. The hand masker will suffice.
heavy_d is offline
Old 01-24-2018, 02:51 PM   #17
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,354
The differences between us are interesting, no one is right or wrong in how we paint. We all have various goals and expectations, and different customers.
I rarely spray interior, (new construction is a different beast)
In an empty house I will spray ceilings but we brush all trim and cut and roll walls.
I have customers who insist we brush the trim, no spraying. It is no problem for us.
Not everyone likes the slick look of a sprayed finish but prefer the rich look of quality brush work.
I sub for a house builder, all we paint for him are the exterior doors, it's not much I know but we always fit him in when he calls. He calls on us because we can brush paint the doors to his standard, my guy gets them perfect every time.
I just don't see spraying as the answer, and I do a lot of exterior spraying.
At the end of the day as long as you enjoy your work, customer is happy and we make a profit then life is good.
Ohio painter is online now
The Following 4 Users Say Thank You to Ohio painter For This Useful Post:
avenge (01-24-2018), Golden view (01-24-2018), KAP (01-24-2018), Sir Mixalot (01-24-2018)
Old 01-24-2018, 02:54 PM   #18
How do you mask off all the door hinges in that time?
The Following User Says Thank You to Ohio painter For This Useful Post:
Old 01-24-2018, 03:29 PM   #19
I'm saying spray it last.
Old 01-24-2018, 03:34 PM   #20
Rewards Points: 614
He only works in tiny house's.
Last week he was saying he couldn't imagine a bathroom taking more than 2 weeks to complete.
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
Ohio painter (01-24-2018)
Crown moulding installation Xtrememtnbiker Finish Carpentry 437 05-18-2015 01:09 AM
Clients occupying crown moulding work area...? kevbo Finish Carpentry 52 07-31-2013 08:48 PM
calculating crown spring angle Mrmac204 Finish Carpentry 12 12-26-2012 07:08 AM
Festool 494369 crown stops for kapex BCConstruction Contractor Swap 4 10-02-2012 09:37 AM
Crown moulding in Kitchen w/ cabinet crown JTW Finish Carpentry 42 07-06-2010 08:26 PM
