Spray Vs Brush
Old 07-14-2005, 01:20 PM   #1
morgan's Avatar
Trade: painting
Spray Vs Brush
i was curious as to peoples preference to spraying an exterior opposed to roll/brushing. does the prep and possible overspray negate the speed of spraying. i've done carports where everything was to be white (pipes, wires, etc...) and spraying was very efficient. i've had limited experience with new housing as well, but the spray rig seemed to be the way to go. i would appreciate anyones stories or experience with spray vs brush as i have an outside to do which is on a bay and is usually windy.
morgan is offline
Old 07-14-2005, 04:52 PM   #2
saucedo80's Avatar
Re: Spray Vs Brush
I always spray exteriors. It is way faster than rolling and brushing even with the prep involved. Just rolling and brushing the eaves alone will take you a couple of days, and spraying them takes you a couple of hours.
even though i spray, i always carry a brush with me to work the paint in when it is wood siding, and to paint areas that would otherwise get over spray, however even in those situations i use the sprayer to get the paint on.
saucedo80 is offline
Old 07-14-2005, 05:06 PM   #3
morgan's Avatar
Trade: painting
Re: Spray Vs Brush
thanks for the reply, i am leaning toward spraying just because the house is so large.
morgan is offline
Old 07-14-2005, 07:45 PM   #4
Zeebo's Avatar
Trade: Painter
Re: Spray Vs Brush
Morgan, I recently purchased liability insurance in ontario, canada....this is where I live. My liability insurance does not cover spraying mishaps (ie. overspray on the neighbours car!!). In fact, my insurance will not cover spraying whatsoever. So you might want to check with your insurance carrier to determine if you have coverage for spraying in interior or exterior. Cheers.
Zeebo
Zeebo is offline
eliminating spray gun splattering saucedo80 Painting & Finish Work 11 11-02-2010 02:47 PM
Painting Exterior EIFS Home / Spray Gun Setup plazaman Painting & Finish Work 9 06-18-2007 11:03 PM
spray, brush, or roll doors? Traditions Painting & Finish Work 13 03-31-2007 10:20 AM
regarding spray painting gregferd Painting & Finish Work 1 03-05-2007 08:34 PM
proper way of loading of brush from a cutting pail Zeebo Painting & Finish Work 7 08-11-2006 11:58 PM
