Spray Tip Size For Cabinets
Old 03-28-2010, 01:09 PM   #1
samccard's Avatar
Trade: Property Preservation and Remodeling.
Rewards Points: 75
I am about to spray my cabinet doors with my 440i and am trying to decide on the best tip to use. I am looking at the 413 for latex enamel. I have never sprayed cabinet doors with an airless sprayer, only hvlp air sprayer. Can anyone tell me which tip may work best. Thanks!
www.destinyhomesinc.com
samccard is offline
Old 03-28-2010, 02:33 PM   #2
woodtradesman's Avatar
Trade: Woodworker, Cabinet Maker and Finish Carpenter
Rewards Points: 154
Re: Spray Tip Size For Cabinets
Titan synergy fine finish tip 671 210 or Graco fine finish tip FF210 (you will need the RAC X tip guard for the graco tip)
The rich rule over the poor, and the borrower is servant to the lender.
woodtradesman is offline
The Following User Says Thank You to woodtradesman For This Useful Post:
BC_Painter (03-28-2010)
Old 03-28-2010, 07:39 PM   #3
samccard's Avatar
Rewards Points: 75
Thanks for the "Tip"!
samccard is offline
Old 05-18-2010, 01:17 PM   #4
sanders's Avatar
Trade: rentals
Send a message via Skype™ to sanders
I also think that 210 will work for ya. It depends if there is an old paint. If not you'd better use 420 or 517 first. 210 wont cover that much. Its just good for finish works.
sanders is offline
Old 05-20-2010, 10:18 PM   #5
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,292
Don't use 420 first. It might be funny at first but then you'll get hungry and Southpark will be on. You'll never finish.
Metro M & L is offline
Old 04-29-2014, 04:57 PM   #6
30 year novice
carzie's Avatar
Trade: Painting contractor
Rewards Points: 1,757
yep
Sorry I was playing with my settings and don't know how to delete a posting.
carzie is offline
Old 05-12-2014, 03:57 AM   #7
Stelzer Painting Inc.
stelzerpainting's Avatar
Trade: 1721
Rewards Points: 358
210 Fine-Finish. If it's a lot of wide-open spaces, 310 Fine-Finish.
stelzerpainting is offline
Spray foam under a slab for insulation -- Mike Finley Construction 22 01-10-2010 02:39 PM
Spray Lines On Smooth Exteriors HELP!!! Entrepreneur Painting & Finish Work 15 04-03-2009 08:15 PM
Does Behr Ext. Satin spray easily? renet Painting & Finish Work 2 11-17-2008 10:31 AM
How do you spray a room - new construction? Zeebo Painting & Finish Work 16 01-27-2008 11:32 AM
Spray King Sprayer for sale JCardoza Tools & Equipment 0 11-05-2007 06:54 PM
