Spray Question
Old 08-15-2007, 09:04 AM   #1
Miller's Avatar
Trade: Painter
Spray Question
Just wondering what the best tip would be for the spraying of some office doors just the Frame not the door. Will be using Oil paint from SW and the Sprayer is a Titan 440.
Thanks,
Miller is offline
Old 08-15-2007, 06:24 PM   #2
Workaholic's Avatar
Trade: Painting Contractor
Re: Spray Question
what kind of oil, like an industrial enamel?
I would use a 211 tip if it was me. Some will tell you to use a fft like a graco 210.
I would put a generous amount of japan drier in the finish, i would not thin it and i would use a titan 211 tip
Sean
Workaholic is offline
Old 08-15-2007, 06:42 PM   #3
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Send a message via Yahoo to painterofeveryt
Re: Spray Question
sorry but I have to say...throw those graco tips in the garbage can ! try a tip from tritech . .google em )also called painters supply direct the feathered edges on these tips are so soft and nice to work with,use em once and you will switch ..the telephone number is (877)572-4683 ask to speak to john plocic the owner,tell him you saw a write up on here and you want a free tip !..he usually comes thru for the first time guys.... just my 2 cents
painterofeveryt is offline
Old 08-15-2007, 09:56 PM   #4
Workaholic's Avatar
Re: Spray Question
i have seen the tritech's before. I usualy run titan tips.
Sean
Old 08-16-2007, 12:09 AM   #5
SgtBaldy's Avatar
Re: Spray Question
Will give tritechs a try. I use titans as well.
Tampa Painters
SgtBaldy is offline
Old 08-16-2007, 09:36 PM   #6
Educated Applicator
MarvinWilleyJr's Avatar
Trade: Painting & Fine Finishes
Send a message via AIM to MarvinWilleyJr
Re: Spray Question
211's are perfect With a 411 if ya had do the doors. Ya just better make sure you strain the paint good, and even put a strainer bag on the foot on the pump too. Just to save you the headache if it clogs.
Used a 209 one time, just as good.....except no speed at all! Take ya twice as long as a 211.
A stupid man's report of what a clever man says is never accurate because he unconsciously translates what he hears into something he can understand.
MarvinWilleyJr is offline
eliminating spray gun splattering saucedo80 Painting & Finish Work 11 11-02-2010 02:47 PM
spray, brush, or roll doors? Traditions Painting & Finish Work 13 03-31-2007 10:20 AM
spray rig wink Painting & Finish Work 6 08-25-2006 09:17 PM
