Spray Lines On Smooth Exteriors HELP!!!
Old 04-02-2009, 04:53 PM   #1
Entrepreneur's Avatar
Hey over the past 2 years I've had around 50 houses sprayed through my business.
I've noticed that on smooth surfaces such as aluminum siding and even solid wood theres loads of lines visible after the spraying is done...it does not look good.
I've tried everything from using more pressure, less pressure, bigger tip size, smaller tip size, I have a Titan 440.
Everyone I've asked now says it comes down to technique but I don't believe that I remember all my first houses came out smooth as a babies bottom.
Soo....what can I do to minizmize spray lines on exteriors? Thanks!
Entrepreneur is offline
Old 04-02-2009, 06:12 PM   #2
410tip's Avatar
Trade: Painting, Residential/light commercial
Re: Spray Lines On Smooth Exteriors HELP!!!
Use a new 515 tip. Flat head or reversible.
Watch your start and stop marks.
Fan out at the beginning and end of your spray sets.
Don't be afraid to put two light coats of paint on each side.
Once you master doing it in two coats, you'll be able to get it to cover in one coat.
Start and stops can be eliminated by fanning out. The heavier you go, the more it'll show.
My 2 cents.
410tip is offline
Old 04-03-2009, 01:16 AM   #3
sparehair's Avatar
Trade: Painting, flooring
backroll?
sparehair is offline
Old 04-03-2009, 01:17 AM   #4
sparehair's Avatar
spray horizontally instead of vertically (running with the siding)?
Old 04-03-2009, 01:42 AM   #5
back roll does work but a waste of labour...i could try spraying with siding i suppose.
Old 04-03-2009, 06:40 AM   #6
A bit abrasive.
WisePainter's Avatar
Overlap 50%.
My advice: Hire a real painter to do it.
WisePainter is offline
The Following User Says Thank You to WisePainter For This Useful Post:
NAV (04-03-2009)
Old 04-03-2009, 09:26 AM   #7
Kayb2's Avatar
Trade: Designer/Contractor
try a new tip
Kayb2 is offline
Old 04-03-2009, 09:39 AM   #8
Traditions2's Avatar
Trade: painting and refinishing
I've been spraying a long time and have to agree. Unless it is a true deadflat paint, I don't like the finish with spraying and not backrolling. If it is on lap siding I don't have a problem. But trying to spray an interior new cons or something like that without backrolling. I can't do it to my liking. I spray ceilings with dead flat paint and don't backroll. Everything else gets backrolled.
Traditions2 is offline
The Following User Says Thank You to Traditions2 For This Useful Post:
sparehair (04-04-2009)
Old 04-03-2009, 03:51 PM   #9
NAV's Avatar
Trade: commercial building restoration
What the heck are you guys telling him to backroll aluminum siding for???
Its a combination of the tip (use a new tip every 2 - 3 houses) pressure (I am a fan of high pressure - just watch the overspray) and the material you are using (if it is too thick you may have problems - try reducing the material by 5% with water).
I had a problem with a case of tips i purchased years ago. they all had manufactures defects and would finger bad. buy a new tip from another store and see if that fixes it.
NAV is offline
Old 04-03-2009, 03:59 PM   #10
I just re-read the post. I wouldn't backbrush or backroll aluminum siding. I'm talking about spraying out interiors. I always back roll. Same thing with doing an exterior house that is wood or stucco. I like to backroll. It puts the product into the substrate. Aluminum siding though, spray and forget it. I love spraying alum sided houses. quick easy money.
Old 04-03-2009, 05:20 PM   #11
Hey thanks for advice.
I am going to try watering down the paint for sure maybe even put in some floodtrol from Flood.
Old 04-03-2009, 05:28 PM   #12
A bit abrasive.
Old 04-03-2009, 05:31 PM   #13
President of the world
world llc's Avatar
Trade: general contractor
my old boss used to water down up to 20%
not sure how it held up, but boy it sure looked good driving away!
world llc is offline
The Following User Says Thank You to world llc For This Useful Post:
NAV (04-03-2009)
Old 04-03-2009, 05:37 PM   #14
world llc's Avatar
to be helpfull, get a bigger unit. i use my speeflo for most situations where i get tails out of my 640ix
speeflo with a graco gun... i get splatter from my titan gun under high pressure
Old 04-03-2009, 06:14 PM   #15
NAV's Avatar
5% water not 50%
NAV is offline
Old 04-03-2009, 08:15 PM   #16
Veith@toast.net's Avatar
Trade: Painting and wallcover
Sounds Like the Biggest problem is tip and low pressure. Ya I agree the pump seam a little small but doable. That And I wonder how much hose he is useing.
David Enterprises Inc.
http://davidspaintingandwallpapering.com/
Veith@toast.net is offline
paint is stippling out of airless spray gun scottcoleman General Discussion 2 01-16-2009 05:59 PM
Does Behr Ext. Satin spray easily? renet Painting & Finish Work 2 11-17-2008 10:31 AM
How do you spray a room - new construction? Zeebo Painting & Finish Work 16 01-27-2008 11:32 AM
Spray King Sprayer for sale JCardoza Tools & Equipment 0 11-05-2007 06:54 PM
